Hi Pattard,
thank you for the answer.
I tried your solution, but didn't work.
The console error is this:
"ImportError: No module named github"
I'm trying to import a module called com.github.imageio, but the
cs-studio didn't find it....
I'm tried another jars that didn't work too. I'm tried to add path inside my code too, but nothing works.
What version of CSS you are using?
Regards
Em 28-11-2016 06:29, Patard Charles-Henri escreveu:
> Hi Gabr iel,
> Can you show the console error ? I’ve got this kind of problem with
> Jython imports. Even if you modify PYTHONPATH or CS-Studio PYTHONPATH
> preferences it doesn’t work. To solve it I needed to create a python
> script named ImportDependencies.py :
> #Python imports
> import sys
> from os.path import expanduser
> # Get Home path
> HOME_PATH = expanduser("~")
> print 'importDependencies HOME_PATH '+str(HOME_PATH)
> # Add librairies
> sys.path.append(str(HOME_PATH)+'/path/to/jar/file')”
> In a second time, you have to import ImprtDependencies.py in your
> Jython/Python script like this : “import ImportDependencies”.
> Best regards.
> /Préservons notre environnement, n’imprimez ce mail que si nécessaire./
> /Preserve our environment, print this email only if necessary./
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
- Re: CSS - Problem importing Jar on Jython Kasemir, Kay
- CSS - Problem importing Jar on Jython Patard Charles-Henri
<2016>
2025
2026
<2016>
2025
2026
