1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS/RTEMS Compilation errors
To: [email protected]
Date: Mon, 28 Nov 2016 09:49:21 -0500
RTEMS version 4.11.
EPICS base3-15.1
I am trying to port the EPICS/RTEMS for Altera Soc FPGA. When I built the epics base, I got these errors
/group/eesicgrp/yanjx/workspace/rtems411/bin/../lib/gcc/arm-rtems4.11/4.9.3/../../../../arm-rtems4.11/bin/ld: error: /group/eesicgrp/yanjx/workspace/bsps/4.11/arm-rtems4.11/altcycv_devkit/lib/librtemscpu.a(libposix_a-killinfo.o) uses VFP register arguments, libComTestHarness does not /group/eesicgrp/yanjx/workspace/rtems411/bin/../lib/gcc/arm-rtems4.11/4.9.3/../../../../arm-rtems4.11/bin/ld: failed to merge target specific data of file /group/eesicgrp/yanjx/workspace/bsps/4.11/arm-rtems4.11/altcycv_devkit/lib/librtemscpu.a(libposix_a-killinfo.o) /u/group/eesicgrp/yanjx/workspace/rtems411/bin/../lib/gcc/arm-rtems4.11/4.9.3/../../../../arm-rtems4.11/bin/ld: error: /group/eesicgrp/yanjx/workspace/bsps/4.11/arm-rtems4.11/altcycv_devkit/lib/librtemscpu.a(libposix_a-psignalsetprocesssignals.o) uses VFP register arguments, libComTestHarness does not /group/eesicgrp/yanjx/workspace/rtems411/bin/../lib/gcc/arm-rtems4.11/4.9.3/../../../../arm-rtems4.11/bin/ld: failed to merge target specific data of file /group/eesicgrp/yanjx/workspace/bsps/4.11/arm-rtems4.11/altcycv_devkit/lib/librtemscpu.a(libposix_a-psignalsetprocesssignals.o) /group/eesicgrp/yanjx/workspace/rtems411/bin/../lib/gcc/arm-rtems4.11/4.9.3/../../../../arm-rtems4.11/bin/ld: error: /group/eesicgrp/yanjx/workspace/bsps/4.11/arm-rtems4.11/altcycv_devkit/lib/librtemscpu.a(libposix_a-psignalunblockthread.o) uses VFP register arguments, libComTestHarness does not /group/eesicgrp/yanjx/workspace/rtems411/bin/../lib/gcc/arm-rtems4.11/4.9.3/../../../../arm-rtems4.11/bin/ld: failed to merge target specific data of file /group/eesicgrp/yanjx/workspace/bsps/4.11/arm-rtems4.11/altcycv_devkit/lib/librtemscpu.a(libposix_a-psignalunblockthread.o)
I can build the RTEMS4.11 and run it on Altera Soc FPGA (altcycv_devkit), but have problem to build the epics base. Does anyone have any idea what is causing this?
Jay Yan
Re: EPICS/RTEMS Compilation errors Benjamin Franksen
Re: EPICS/RTEMS Compilation errors Andrew Johnson
Prev: Re: CSS - Problem importing Jar on Jython Kasemir, Kay
Next: Asyn daemon + console + log Benoit RAT
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS and Beckhoff Jameson Graef Rollins
Next: Re: EPICS/RTEMS Compilation errors Benjamin Franksen
ANJ, 28 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
