1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: SNL sequencer apparently losing connection to underlying network
To: [email protected]
Date: Mon, 28 Nov 2016 17:17:30 +0100 (CET)
I have a weird situation: On the same host I have one IOC (with all PVs) and about 4 stand-alone SNL sequencer applications (with no databases) that interact with each other (interfaced via the PVs).
In one of the sequencers, I have a call out to to a Python script that calls a web service (to Olog, to create an electronic lab-book entry).
If all the sequencers are running, I can get this one sequencer to lose low-level connection to the network layer and EPICS.
The pvConnectCount() returns 7, for example, but a monitored PV does not get updated. I can terminate the IOC and still the pvConnectCount() shows 7.
If I manually stop the sequencer (seqStop xxxx), the try and restart it (seq xxxx), it then fails to start (even if the IOC and all other sequencers are still functioning normally).
To repeat: when the "sensitive" sequencer stops working, no other application is affected - all the other sequencers still work, "caget/caput" from the command-line still works, etc.
Sometimes the /var/log/messages shows e1000 network module issues:
Nov 23 14:10:27 localhost kernel: e1000: eth0: e1000_clean_tx_irq: Detected Tx Unit Hang
Nov 23 14:11:42 localhost kernel: e1000: eth0: e1000_watchdog_task: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
Nov 23 14:11:52 localhost kernel: e1000: eth0: e1000_watchdog_task: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None
but not always!
To make matters more bizarre, if I stop one of the other sequencers, then this troublesome one functions perfectly!!
Some system information:
hostname 2.6.32-431.20.3.el6.x86_64 #1 SMP Fri Jun 6 18:30:54 EDT 2014 x86_64 x86_64 x86_64 GNU/Linux
epics          : Experimental Physics and Industrial Control Syste (3.15.5~rc1)
Has anyone seen anything like this before? Do you have any hints for me, where to look?
Kevin
Kevin Meyer
Cosylab, Ljubljana, Slovenia
Telephone: +386-(0)1-320-47-82   Mobile: +386-(0)70-260-321
Prev: Asyn daemon + console + log Benoit RAT
Next: RE: Asyn daemon + console + log Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Asyn daemon + console + log Benjamin Franksen
Next: Re: SNL sequencer apparently losing connection to underlying network Kevin Meyer
ANJ, 29 Nov 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
