1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: hrSeqCt_ALL pv question
To: 梁雅翔 <[email protected]>
Cc: "Hu, Michael Y." <[email protected]>, tech-talk <[email protected]>
Date: Fri, 2 Dec 2016 05:34:26 +0000
Hi Liang,
CSS-BOY pays closer attention to record status and severity than the MEDM displays we use for this database.  The PVs are invalid because the records have never been processed.  But the records aren't supposed to be processed; they are just supposed to hold values.  My advice is to ignore these apparent errors for now and move on to the next layer of problems.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
Sent: Thursday, December 01, 2016 9:09 PM
To: Mooney, Tim M.
Cc: tech-talk
Subject: hrSeqCt_ALL pv question
Hello Tim,
       It is much better I do as you said. I changed the SW1, X1,theta1,.... to m1,m2,m3,.... in motor.substitutions.ARIES.test.xxx. St.cmd no change.
       Much was good, but the hrSeqCt_ALL has some pv invalid, the invalid pv name was:
       xxx:HR1_ETweakAl  ,                     xxx:HR1_ETweakAl.EGU,
       xxx:HR1_LambdaTweakAl   ,         xxx:HR1_LambdaTweakAl.EGU,
       xxx:HR1_phi1OffA0   ,                    xxx:HR1_phi1OffA0.EGU,
       xxx:HR1_phi2OffA0 ,
       xxx:HR1_phi2SetA0 (I wo nder that  xxx:HR1_phi1SetA0 was valid only one time and I don't think I changed something, xxx:HR1_phi2SetA0 was invalid always.),
       xxx:HR1_worldOffA0.EGU.
       P.S. The attachment named "hrSeqCt_ALL(some pv invalid).png" was my screen snapshot of CSS GUI, maybe it is clear.
       I tried something to solve the question, but I do not understand the setting and I had a little time left, please give me some instruction.
       Thank you so much.
       the file, st.cmd, output and *.substitutions was below.
Liang
my macro
P        xxx:
M1     m1
M2     m2
M3     m3
M4     m4
M5     m5
M6     m6
M7     m7
N        1
//////////////////////////////////////////////////////          st.cmd        ///////////////////////////////////////////////////////////////////////////////////
# Linux startup script
< envPaths
# For devIocStats
#epicsEnvSet("ENGINEER","engineer")
#epicsEnvSet("LOCATION","location")
epicsEnvSet("GROUP","group")
epicsEnvSet("STREAM_PROTOCOL_PATH","$(TOP)")
# save_restore.cmd needs the full path to the startup directory, which
# envPaths currently does not provide
epicsEnvSet(STARTUP,$(TOP)/iocBoot/$(IOC))
# Increase size of buffer for error logging from default 1256
errlogInit(20000)
# Specify largest array CA will transport
# Note for N doubles, need N*8 bytes+some overhead
epicsEnvSet EPICS_CA_MAX_ARRAY_BYTES 64010
# Tell EPICS all about the record types, device-support modules, drivers,
# etc. in the software we just loaded (xxx.munch)
dbLoadDatabase("../../dbd/iocxxxLinux.dbd")
iocxxxLinux_registerRecordDeviceDriver(pdbbase)
### save_restore setup
#< save_restore .cmd
# Access Security
#dbLoadRecords("$(TOP)/xxxApp/Db/Security_Control.db","P=xxx:")
#asSetFilename("$(TOP)/iocBoot/accessSecurity.acf")
#asSetSubstitutions("P=xxx:")
### caputRecorder
# trap listener
#dbLoadRecords("$(CAPUTRECORDER)/caputRecorderApp/Db/caputPoster.db","P=xxx:,N=300")
#doAfterIocInit("registerCaputRecorderTrapListener('xxx:caputRecorderCommand')")
# GUI database
#dbLoadRecords("$(CAPUTRECORDER)/caputRecorderApp/Db/caputRecorder.db","P=xxx:,N=300")
# second copy of GUI database
#dbLoadRecords("$(CAPUTRECORDER)/caputRecorderApp/Db/caputRecorder.db","P=xxxA:,N=300")
# if you have hdf5 and szip, you can use this
#< areaDetector.cmd
# soft scaler for testing
#< softScaler.cmd
# user-assignable ramp/tweak
#dbLoadRecords("$(STD)/stdApp/Db/ramp_tweak.db","P=xxx:,Q=rt1")
# serial support
#< serial.cmd
# Motors
dbLoadTemplate("motor.substitutions.ARIES. test.xxx")
drvAsynIPPortConfigure("L0","192.168.1.120:12321",0,0,0)
#< motorSim.cmd
dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=xxx:")
ARIESSetup(4, 5)
ARIESConfig(0, "L0", 0)
var drvARIESdebug 4
#asynSetTraceIOMask("L0",-1,0x9)
### Scan-support software
# crate-resident scan.  This executes 1D, 2D, 3D, and 4D scans, and caches
# 1D data, but it doesn't store anything to disk.  (See 'saveData' below for that.)
dbLoadRecords("$(SSCAN)/sscanApp/Db/standardScans.db","P=xxx:,MAXPTS1=1000,MAXPTS2=1000,MAXPTS3=1000,MAXPTS4=1000,MAXPTSH=1000")
dbLoadRecords("$(SSCAN)/sscanApp/Db/saveData.db","P=xxx:")
# Run this after iocInit:
#doAfterIocInit("saveData_Init(saveData.req, 'P=xxx:')")
dbLoadRecords("$(SSCAN)/sscanApp/Db/scanProgress.db","P=xxx:scanProgress:")
#doAfterIocInit("seq &scanProgress, 'S=xxx:, P=xxx:scanProgress:'")
# configMenu example.
dbLoadRecords("$(AUTO SAVE)/asApp/Db/configMenu.db","P=xxx:,CONFIG=scan1")
# Note that the request file MUST be named $(CONFIG)Menu.req
# If the macro CONFIGMENU is defined with any value, backup (".savB") and
# sequence files (".savN") will not be written.  We don't want these for configMenu.
#doAfterIocInit("create_manual_set('scan1Menu.req','P=xxx:,CONFIG=scan1,CONFIGMENU=1')")
# You could make scan configurations read-only:
#dbLoadRecords("$(AUTOSAVE)/asApp/Db/configMenu.db","P=xxx:,CONFIG=scan1,ENABLE_SAVE=0")
# read-only configMenu example.  (Read-only, because we're not calling create_manual_set().)
#dbLoadRecords("$(AUTOSAVE)/asApp/Db/configMenu.db","P=xxx:,CONFIG=scan2")
# A set of scan parameters for each positioner.  This is a convenience
# for the user.  It can contain an entry for each scannable thing in the
# crate.
dbLoadTemplate("scanParms.substitutions")
### Optical tables
dbLoa dRecords("$(OPTICS)/opticsApp/Db/table.db","P=xxx:,Q=Table1,T=table1,M0X=m1,M0Y=m2,M1Y=m3,M2X=m4,M2Y=m5,M2Z=m6,GEOM=SRI")
dbLoadRecords("$(OPTICS)/opticsApp/Db/table.db","P=xxx:,Q=Table1,T=table1,M0X=m1,M0Y=m2,M1Y=m3,M2X=m4,M2Y=m5,M2Z=m6,GEOM=NEWPORT")
dbLoadRecords("$(OPTICS)/opticsApp/Db/table.db","P=xxx:,Q=Table2,T=table2,M0X=m1,M0Y=m2,M1Y=m3,M2X=m4,M2Y=m5,M2Z=m6,GEOM=SRI")
# Io calculation
dbLoadRecords("$(OPTICS)/opticsApp/Db/Io.db","P=xxx:Io:")
### Monochromator support ###
# Kohzu and PSL monochromators: Bragg and theta/Y/Z motors
# standard geometry (geometry 1)
dbLoadRecords("$(OPTICS)/opticsApp/Db/kohzuSeq.db","P=xxx:,M_THETA=m1,M_Y=m2,M_Z=m3,yOffLo=17.4999,yOffHi=17.5001")
#doAfterIocInit("seq &kohzuCtl, 'P=xxx:, M_THETA=m1, M_Y=m2, M_Z=m3, GEOM=1, logfile=kohzuCtl.log'")
# modified geometry (geometry 2)
#dbLoadRecords("$(OPTICS)/opticsApp/Db/kohzuSeq.db","P=xxx:,M_THETA=m1,M_Y=m2,M_Z=m2,yOf fLo=4,yOffHi=36")
#doAfterIocInit("seq &kohzuCtl, 'P=xxx:, M_THETA=m1, M_Y=m2, M_Z=m3, GEOM=2, logfile=kohzuCtl.log'")
# Spherical grating monochromator
#dbLoadRecords("$(OPTICS)/opticsApp/Db/SGM.db","P=xxx:,N=1,M_x=m7,M_rIn=m6,M_rOut=m8,M_g=m9")
# 4-bounce high-resolution monochromator
dbLoadRecords("$(OPTICS)/opticsApp/Db/hrSeq.db","P=xxx:,N=1,M_PHI1=m4,M_PHI2=m5")
#doAfterIocInit("seq &hrCtl, 'P=xxx:, N=1, M_PHI1=m4, M_PHI2=m5, logfile=hrCtl.log'")
### Orientation matrix, four-circle diffractometer (see seq program 'orient' below)
#dbLoadRecords("$(OPTICS)/opticsApp/Db/orient.db", "P=xxx:,O=1,PREC=4")
#dbLoadTemplate("orient_xtals.substitutions")
#doAfterIocInit("seq &orient, 'P=xxx:orient1:,PM=xxx:,mTTH=m9,mTH=m10,mCHI=m11,mPHI=m12'")
### Stuff for user programming ###
#< calc.cmd
# 4-step measurement
#dbLoadRecor ds("$(STD)/stdApp/Db/4step.db", "P=xxx:,Q=4step:")
# Slow feedback
#dbLoadTemplate "pid_slow.substitutions"
#dbLoadTemplate "async_pid_slow.substitutions"
#dbLoadTemplate "fb_epid.substitutions"
# Miscellaneous PV's, such as burtResult
#dbLoadRecords("$(STD)/stdApp/Db/misc.db","P=xxx:")
### Load database records for Femto amplifiers
#dbLoadRecords("$(STD)/stdApp/Db/femto.db","P=xxx:,H=fem01:,F=seq01:")
#doAfterIocInit("seq femto,'name=fem1,P=xxx:,H=fem01:,F=seq01:,G1=xxx:Unidig1Bo6,G2=xxx:Unidig1Bo7,G3=xxx:Unidig1Bo8,NO=xxx:Unidig1Bo10'")
### Load database records for dual PF4 filters
#dbLoadRecords("$(OPTICS)/opticsApp/Db/pf4common.db","P=xxx:,H=pf4:,A=A,B=B")
#dbLoadRecords("$(OPTICS)/opticsApp/Db/pf4bank.db","P=xxx:,H=pf4:,B=A")
#dbLoadRecords("$(OPTICS)/opticsApp/Db/pf4bank.db","P=xxx:,H=pf4:,B=B")
#doAfterIocInit("seq pf4,'name=pf1,P=xxx:,H=pf4:,B=A,M=xxx: userTran10.I,B1=xxx:userTran10.A,B2=xxx:userTran10.B,B3=xxx:userTran10.C,B4=xxx:userTran10.D'")
#doAfterIocInit("seq pf4,'name=pf2,P=xxx:,H=pf4:,B=B,M=xxx:userTran10.I,B1=xxx:userTran10.E,B2=xxx:userTran10.F,B3=xxx:userTran10.G,B4=xxx:userTran10.H'")
iocInit
motorUtilInit('xxx:')
# write all the PV names to a local file
dbl > dbl-all.txt
# Report  states of database CA links
#dbcar(*,1)
# print the time our boot was finished
date
///////////////////////////////////////////////////////////////                  Output of st.cmd                      ////////////////////////////////////////////////////////////////////////////////////////////////////////////
[root@localhost iocLinux]# ../../bin/linux-x86_64/xxx st.cmd
Successfully locked memory using mlockAll
< envPaths
epicsEnvSet("ARCH","linux-x86_64")
epicsEnvSet("IOC","iocLinux")
epicsEnvSet("TOP","/opt/synApps_5_8/support/xxx-5-8-3")
epicsEnvSet("SUPPORT","/opt/synApps_5_8/support")
epicsEnvSet("EPICS_BASE","/opt/base")
epicsEnvSet("ALIVE","/opt/synApps_5_8/support/alive-1-0")
epicsEnvSet("ALLEN_BRADLEY","/opt/synApps_5_8/support/allenBradley-2-3")
epicsEnvSet("AREA_DETECTOR","/opt/synApps_5_8/support/areaDetector-R2-0")
epicsEnvSet("ADCORE","/opt/synApps_5_8/support/areaDetector-R2-0/ADCore-R2-2")
epicsEnvSet("ADBINARIES","/opt/synApps_5_8/support/areaDetector-R2-0/ADBinaries-R2-2")
epicsEnvSet("ASYN","/opt/synApps_5_8/support/asyn-4-26")
epicsEnvSet("AUTOSAVE","/opt/synApps_5_8/support/autosave-5-6-1")
epicsEnvSet("BUSY","/opt/synApps_5_8/support/busy-1-6-1")
epicsEnvSet("CALC","/opt/synApps_5_8/s upport/calc-3-4-2-1")
epicsEnvSet("CAMAC","/opt/synApps_5_8/support/camac-2-7")
epicsEnvSet("CAPUTRECORDER","/opt/synApps_5_8/support/caputRecorder-1-6")
epicsEnvSet("DAC128V","/opt/synApps_5_8/support/dac128V-2-8")
epicsEnvSet("DELAYGEN","/opt/synApps_5_8/support/delaygen-1-1-1")
epicsEnvSet("DEVIOCSTATS","/opt/synApps_5_8/support/devIocStats-3-1-13")
epicsEnvSet("DXP","/opt/synApps_5_8/support/dxp-3-4")
epicsEnvSet("IP","/opt/synApps_5_8/support/ip-2-17")
epicsEnvSet("IP330","/opt/synApps_5_8/support/ip330-2-8")
epicsEnvSet("IPAC","/opt/synApps_5_8/support/ipac-2-13")
epicsEnvSet("IPUNIDIG","/opt/synApps_5_8/support/ipUnidig-2-10")
epicsEnvSet("LOVE","/opt/synApps_5_8/support/love-3-2-5")
epicsEnvSet("MCA","/opt/synApps_5_8/support/mca-7-6")
epicsEnvSet("MEASCOMP","/opt/synApps_5_8/support/measComp-1-1")
epicsEnvSet("MODBUS","/opt/synApps_5_8/support/modbus-2-7")
epicsEnvSet("MOTOR","/opt/synApps_5_8/support/motor-6-9")
epics EnvSet("OPTICS","/opt/synApps_5_8/support/optics-2-9-3")
epicsEnvSet("QUADEM","/opt/synApps_5_8/support/quadEM-5-0")
epicsEnvSet("SNCSEQ","/opt/synApps_5_8/support/seq-2-2-3")
epicsEnvSet("SOFTGLUE","/opt/synApps_5_8/support/softGlue-2-4-3")
epicsEnvSet("SSCAN","/opt/synApps_5_8/support/sscan-2-10-1")
epicsEnvSet("STD","/opt/synApps_5_8/support/std-3-4")
epicsEnvSet("STREAM","/opt/synApps_5_8/support/stream-2-6a")
epicsEnvSet("VAC","/opt/synApps_5_8/support/vac-1-5-1")
epicsEnvSet("VME","/opt/synApps_5_8/support/vme-2-8-2")
epicsEnvSet("XXX","/opt/synApps_5_8/support/xxx-5-8-3")
# For devIocStats
epicsEnvSet("STREAM_PROTOCOL_PATH","/opt/synApps_5_8/support/xxx-5-8-3")
epicsEnvSet(STARTUP,/opt/synApps_5_8/support/xxx-5- 8-3/iocBoot/iocLinux)
errlogInit(20000)
#< save_restore.cmd
# Access Security
### caputRecorder
# trap listener
#doAfterIocInit("registerCaputRecorderTrapListener('xxx:caputReco rderCommand')")
# GUI database
#< areaDetector.cmd
#< softScaler.cmd
# serial support
#< serial.cmd
# Motors
dbLoadTemplate("motor.substitutions.ARIES.test.xxx")
#< motorSim.cmd
dbLoadRecords("/opt/synApps_5_8/support/motor-6-9/db/motorUtil.db", "P=xxx:")
ARIESSetup(4, 5)
var drvARIESdebug 4
# 1D data, but it does n't store anything to disk.  (See 'saveData' below for that.)
dbLoadRecords("/opt/synApps_5_8/support/sscan-2-10-1/sscanApp/Db/standardScans.db","P=xxx:,MAXPTS1=1000,MAXPTS2=1000,MAXPTS3=1000,MAXPTS4=1000,MAXPTSH=1000")
dbLoadRecords("/opt/synApps_5_8/support/sscan-2-10-1/sscanApp/Db/saveData.db","P=xxx:")
dbLoadRecords("/opt/synApps_5_8/support/sscan-2-10-1/sscanApp/Db/scanProgress.db","P=xxx:scanProgress:")
dbLoadRecords("/opt/synApps_5_8/support/autosave-5-6-1/asApp/Db/configMenu.db","P=xxx:,CONFIG=scan1")
# crate.
### Optical tables
dbLoadRecords("/opt/synApps_5_8/support/optics-2-9-3/opticsApp/Db/table.db","P=xxx:,Q=Table1,T=table1,M0X=m1,M0Y=m2,M1Y=m3,M2X=m4,M2Y=m5,M2Z=m6,GEOM=SRI")
dbLoadRecords("/opt/synApps_5_8/support/optics-2-9-3/opticsApp/Db/table.db","P=xxx:,Q=Table1,T=table1,M0X=m1,M0Y=m2,M1Y=m3,M2X=m4,M2Y=m5,M2Z=m6,GEOM=NE WPORT")
dbLoadRecords("/opt/synApps_5_8/support/optics-2-9-3/opticsApp/Db/table.db","P=xxx:,Q=Table2,T=table2,M0X=m1,M0Y=m2,M1Y=m3,M2X=m4,M2Y=m5,M2Z=m6,GEOM=SRI")
# Io calculation
dbLoadRecords("/opt/synApps_5_8/support/optics-2-9-3/opticsApp/Db/Io.db","P=xxx:Io:")
dbLoadRecords("/opt/synApps_5_8/support/optics-2-9-3/opticsApp/Db/kohzuSeq.db","P=xxx:,M_THETA=m1,M_Y=m2,M_Z=m3,yOffLo=17.4999,yOffHi=17.5001")
#dbLoadRecords("$(OPTICS)/opticsApp/Db/kohzuSeq.db","P=xxx:,M_THETA=m1,M_Y=m2,M_Z=m2,yOffLo=4,yOffHi=36")
# Spherical gr ating monochromator
dbLoadRecords("/opt/synApps_5_8/support/optics-2-9-3/opticsApp/Db/hrSeq.db","P=xxx:,N=1,M_PHI1=m4,M_PHI2=m5")
#< calc.cmd
#dbLoadRecords("$(STD)/stdApp/Db/4step.db", "P=xxx:,Q=4step:")
# Slow feedback
#dbLoadTemplate "async_pid_slow.substitutio ns"
#doAfterIocInit("seq pf4,'name=pf1,P=xxx:,H=pf4:,B=A,M=xxx:userTran10.I,B1=xxx:userTran10.A,B2=xxx:userTran10.B,B3=xxx:userTran10.C,B4=xxx:userTran10.D'")
#doAfterIocInit("seq pf4,'name=pf2,P=xxx:,H=pf4:,B=B,M=xxx:userTran10.I,B1=xx x:userTran10.E,B2=xxx:userTran10.F,B3=xxx:userTran10.G,B4=xxx:userTran10.H'")
iocInit
Starting iocInit
## EPICS R3.15.2 $Date: Thu 2015-05-14 14:09:28 +0200$
## EPICS Base built Oct 16 2016
recDynLinkOut: waiting for CA context
recDynLinkOut: got CA context
saveData: message queue created
saveData:maxAllowedRetries = 10
saveData:retryWaitInSecs = 15
sevr=info Sequencer release 2.2.3, compiled Wed Nov 30 16:54:39 2016
sevr=info Spa wning sequencer program "scanProgress", thread 0x1f75820: "scanProgress"
sevr=info Spawning sequencer program "hrCtl", thread 0x1f7f1d0: "hrCtl"
save_restore:readReqFile: unable to open file configMenu.req. Exiting.
save_restore:readReqFile: unable to open file scan_settings.req. Exiting.
sevr=info scanProgress[0]: all channels connected & received 1st monitor
sevr=info hrCtl[0]: all channels connected & received 1st monitor
dbl > dbl-all.txt
#dbcar(*,1)
# print the time our boot was fi nished
date
2016/12/02 11:04:28.243224
epics> scan1Menu.sav: 0 of 0 PV's connected
///////////////////////////////     scanParm.substitutions    /////////////////////////////////////////////
file "$(SSCAN)/sscanApp/Db/scanParms.db"
{P=xxx:,SCANREC=xxx:scan1,Q=m1,POS="$(Q).VAL",RDBK="$(Q).RBV"}
{P=xxx:,SCANREC=xxx:scan1,Q=m2,POS="$(Q).VAL",RDBK="$(Q).RBV"}
{P=xxx:,SCANREC=xxx:scan1,Q=m3,POS="$(Q).VAL",RDBK="$(Q).RBV"}
{P=xxx:,SCANREC=xxx:scan1,Q=m4,POS="$(Q).VAL",RDBK="$(Q).RBV"}
{P=xxx:,SCANREC=xxx:scan1,Q=m5,POS="$(Q).VAL",RDBK="$(Q).RBV"}
{P=xxx:,SCANREC=xxx:scan1,Q=m6,POS="$(Q).VAL",RDBK="$(Q).RBV"}
{P=xxx:,SCANREC=xxx:scan1,Q=m7,POS="$(Q).VAL",RDBK="$(Q).RBV"}
{P=xxx:,SCANREC=xxx:scan1,Q=m8,POS="$(Q).VAL",RDBK="$(Q).RBV"}
{P=xxx:,SCANREC=xxx:scan1,Q=Table1X,POS=table1.X,RDBK=table1.XRB}
{P=xxx:,SCANREC=xxx:scan1,Q=Table1Y,POS=table1.Y,RDBK=table1.YRB}
{P=xxx:,SCANREC=xxx:scan1,Q=Table1Z,POS=table1.Z,RDBK=table1.ZRB}
{P=xxx:,SCANREC=xxx:scan1,Q=Table1AX,POS=table1.AX,RDBK=table1.AXRB}
{P=xxx:,SCANREC=xxx:scan1,Q=Table1AY,POS=table1.AY,RDBK=table1.AYRB}
{P=xxx:,SCANREC=xxx:scan1,Q=Table1AZ,POS=table1.AZ,RDBK=table1.AZRB}
{P=xxx:,SCANREC=xxx:scan1,Q=BraggE,POS=BraggEAO.VAL,RDBK=BraggERdbkAO.VAL}
{P=xxx:,SCANREC=xxx:scan1,Q=BraggLambda,POS=BraggLambdaAO.VAL,RDBK=BraggLambdaRdbkAO.VAL}
{P=xxx:,SCANREC=xxx:scan1,Q=BraggTheta,POS=BraggThetaAO.VAL,RDBK=BraggThetaRdbkAO.VAL}
{P=xxx:,SCANREC=xxx:scan1,Q=HR1_E,POS=HR1_EAO.VAL,RDBK=HR1_ERdbkAO}
{P=xxx:,SCANREC=xxx:scan1,Q=HR1_A,POS=HR1_worldOffAO.VAL,RDBK=HR1_worldOffAO.VAL}
# slit
#{P=xxx:,SCANREC=xxx:scan1,Q=Slit1Hp,POS=Slit1Hxp.VAL,RDBK=Slit1Ht2.A}
#{P=xxx:,SCANREC=xxx:scan1,Q=Slit1Hn,POS=Slit1Hxn.VAL,RDBK=Slit1Ht2.B}
#{P=xxx:,SCANREC=xxx:scan1,Q=Slit1Hsize,POS=Slit1Hsize.VAL,RDBK=Slit1Ht2.C}
#{P=xxx:,SCANREC=xxx:scan1,Q=Slit1Hcenter,POS=Slit1Hcenter.VAL,RDBK=Slit1Ht2.D}
#{P=xxx:,SCANREC=xxx:scan1,Q=Slit1Vp,POS=Slit1Vxp.VAL,RDBK=Slit1Vt2.A}
#{P=xxx:,SCANREC=xxx:scan1,Q=Slit1Vn,POS=Slit1Vxn.VAL,RDBK=Slit1Vt2.B}
#{P=xxx:,SCANREC=xxx:scan1,Q=Slit1Vsize,POS=Slit1Vsize.VAL,RDBK=Slit1Vt2.C}
#{P=xxx:,SCANREC=xxx:scan1,Q=Slit1Vcenter,POS=Slit1Vcenter.VAL,RDBK=Slit1Vt2.D}
////////////////////////     motor.substitutions.ARIES.test.xxx    //////////////////////////////////
file "$(MOTOR)/db/basic_motor.db"
pattern
{P,     N,       M,        DTYP,    C,  S,  DESC,          EGU,      DIR,  VELO,     VBAS,  ACCL,  BDST,  BVEL,    BACC,   MRES,   PREC,   DHLM,       DLLM,  INIT}
{xxx:,  m1,    "$(N)",  "ARIES",   0,  0,  "motor $(N)",  rad,      Pos,  2000,     400,    .1,    1,     400,     .1,    2,       5,     5001,      -5001,  ""}
{xxx:,  m2,  "$(N)",  "ARIES",  0,  1,  "motor $(N)",  arcsec,   Pos,  2000,     400,    .1,    1,     400,     .1,    0.0225,  5,     50000001,   -5000000001,  ""}
{xxx:,  m3,      "$(N)",  "ARIES",  0,  2,  "motor $(N)",  um,       Pos,  10,        .1,    .2,    0,     1,       .2,    0.5,     5,     360,       -360,  ""}
{xxx:,  m4,      "$(N)",  "ARIES",  0,  3,  "motor $(N)",  um,       Pos,  1000,     200,    .1,    1,     200,     .1,    0.05,    5,     15001,     -15001,  ""}
{xxx:,  m5,  "$(N)",  "ARIES",  0,  4,  "motor $(N)",  arcsec,   Pos,  1000,     200,    .1,    1,     200,     .1,    0.00225,  5,    15001,     -15001,  ""}
{xxx:,  m6,     "$(N)",  "ARIES",   0,  5,  "motor $(N)",  um,       Pos,  1000,     200,    .1,    1,     200,     .1,    0.05,    5,     15001,     -15001,  ""}
{xxx:,  m7,     "$(N)",  "ARIES",   0,  6,  "motor $(N)",  um,       Pos,  1000,     200,    .1,    1,     200,     .1,    0.05,    5,     15001,     -15001,  ""}
hrSeqCt_ALL pv question 梁雅翔
Prev: hrSeqCt_ALL pv question 梁雅翔
Next: How to setup Alarm system 장진수
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 01 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
