Hi Palak,
I presume the question you are asking is how to detach screens from
the main session. The eclipse platform by default opens screens
inside the main window. There are several options you can use to
open screens independently:
1) You could drag the tab for an open screen to "detach" for
displaying on your "secondary" monitor. Likewise you can stack
several screens by dragging them into the same window.
2) If you created a top menu opi screen that uses action buttons to
open particular screens, you can open the screen in a new window by
holding <shift> when clicking the action button. Holding down
<control> while clicking the action button will open the
screen as a separate tab in the window.
Tim
On 12/2/16 1:51 AM, palak shimpee
wrote:
I have made a project in CSS and I different opi
files in same project. I want to display these opi on different
monitors. So can I connect these monitors using VGA cables and
use virtual screens?
- Re: display two opi viewers on different monitors Paul Sichta
- display two opi viewers on different monitors palak shimpee
Re: SNL sequencer apparently losing connection to underlying network Kevin Meyer
<2016>
2025
2026
<2016>
2025
2026
ANJ, 02 Dec 2016 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
