1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Simultaneous Channel access
To: <[email protected]>
Date: Mon, 5 Dec 2016 13:45:54 +0000
Hello,
I have an issue with Epics V4 PvaClientChannel, working in a Java environment on the v4.2.2 jars.
I’m developing a client application, and in normal operations, it all works fine - I can create a PvaClientChannel to the server, make PvaClientGet requests, and PvaClientRPC calls.
The problem occurs when I try to do more than one of these at once. For example, if the server is taking a long time to process the PvaClientRPC call, if on another Thread I attempt to do a PvaClientGet or another PvaClientRPC call, it times out when connecting to the channel in the PvaClientChannel.waitConnect(timeout) call.
I’ve tried everything I can think of – using the async call to PvaClientRPC.request(), creating a new PvaClient object for each call (instead of using PvaClient.get(“pva”), going back to using the ‘older’ Channel and ChannelRPC async way of doing things, but I still get the same problem.
The problem isn’t in the server because if I create a separate application to do the second Get or RPC call whilst the first is still waiting, then the server processes it fine.
The way I am creating the channels for each call is
PvaClientchannel pvaChannel = PvaClient.get(“pva”).createChannel(“mydevice”,”pva”);
pvaChannel.issueConnect();
Status status = pvaChannel.waitConnect(5);
Is there another way to do this that allows multiple simultaneous channel access?
Please help!
Matt
Re: Simultaneous Channel access Marty Kraimer
Prev: Re: Capturing data from string which is sent by device Pilkyu Jung
Next: RE: Capturing data from string which is sent by device Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AreaDetector Interface for Dectris EIGER? Bruno Martins
Next: Re: Simultaneous Channel access Marty Kraimer
ANJ, 05 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
