1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics V4 Questions - New to Epics 4
To: "Madden, Timothy J." <[email protected]>
Cc: "Veseli, Sinisa" <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Tue, 6 Dec 2016 02:44:31 +0000
Hi Tim, explanation by example:
First the familiar; get the field of a quadrupole, using
the eget EPICS 4 command, telling it to use the Channel Access protocol
(-p ca). I could have added -m to say monitor it.
$ eget -p ca QUAD:LTU1:880:BACT
14.036
Now, what are the optics right now at that quad? That’s
computed by the online model. The Twiss parameters are available as a structure,
returned over pvAccess (V4):
[physics@lcls-srv01 ~/greg]$ eget -s QUAD:LTU1:880:TWISS
non-normative type
structure
    double energy 14.525
    double psix 75.1573
    double alphax 85.5249
    double betax 1.83101
    double etax -0.0874823
    double etaxp 0.00345222
    double psiy 63.7057
    double alphay 26.1492
    double betay 3.69231
    double etay -3.02964e-05
    double etayp 3.23509e-06
    double z 3555.94
    double leff 0.316
    double sleff 0.158
    int ordinality 3364
Ok, if that’s the optics right now, let’s compare those to the *design* Twiss
parameters, from the model run we did for this machine configuration. Note
arguments.
[physics@lcls-srv01 ~/greg]$ eget -s QUAD:LTU1:880:TWISS -a type design -a run 46696
non-normative type
structure
    double energy 14.583
    double psix 75.2175
    double alphax 131.746
    double betax 3.47598
    double etax -0.0815512
    double etaxp 0.0042281
    double psiy 64.2223
    double alphay 38.2057
    double betay 3.74104
    double etay -5.1665e-05
    double etayp 3.3515e-06
    double z 3555.94
    double leff 0.316
    double sleff 0.158
    int ordinality 3360
Is that a bit clearer? In shameless self promotion - you might see the talk I
gave for the ESS (Lund) EPICS meeting. It has a number of examples of V4 from
different labs, plus some timing measurements and basic architecture outline.
https://indico.esss.lu.se/event/507/session/2/contribution/51
Cheers
Greg
> On Dec 5, 2016, at 5:26 PM, Ralph Lange <[email protected]> wrote:
> Hi Tim,
> Answering a specific one of your questions:
> On Tue, Dec 6, 2016 at 7:45 AM, Madden, Timothy J. <[email protected]> wrote:
> General question:
>  I know RPC stands for remote procedure call, but what does it mean in epics V4?
> What does it do that epics V3 does not do?
> Maybe it is easier to answer in terms of data structures:
> "Normal" connections and subscriptions are using a single data type, which may be a structure in V4, but it is fixed during the connection lifetime, and it is the same structure on read, write and subscription operations.
> RPC type connections may have different data types on write and read, and the returned structure may change with every call of the method.
> Thus, the RPC type connections are well suited to middle-layer type services, where the data written (think: small list of arguments) are very different from the returned values (think: big arrays of structures that depend on the sent arguments).
> Cheers,
> ~Ralph
Re: Epics V4 Questions - New to Epics 4 Ralph Lange
Prev: Re: Epics V4 Questions - New to Epics 4 Ralph Lange
Next: Re: deadlock in pcas 3.14.12.6-rc1 Bruce Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <2016>  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: BEAST alarm plugin. 장진수
ANJ, 05 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
