hi, first, it shows the error: make[1]: Entering directory `/usr/local/epics/r3.14.12.5/extensions/src/edm/giflib/O.linux-x86_64'
/usr/bin/g++ -o libcf322683-513e-4570-a44b-7cdd7cae0de5.so -shared -fPIC -Wl,-hlibcf322683-513e-4570-a44b-7cdd7cae0de5.so -L/usr/local/epics/r3.14.12.5/extensions/lib/linux-x86_64 -L/usr/l\ ib/x86_64-linux-gnu -Wl,-rpath,/usr/local/epics/r3.14.12.5/extensions/lib/linux-x86_64 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -m64 gif.o reg_libcf322683-513e-4570-a44b-\ 7cdd7cae0de5.o -lEdmBase -lcfcaa62e-8199-11d3-a77f-00104b8742df -l114135a4-6f6c-11d3-95bc-00104b8742df -lXm -lXt -lXp -lXtst -lX11 -lpthread -ldl -lungif -lgif -lpthread -lreadline -l\ m -lrt -ldl -lgcc /usr/bin/ld: cannot find -lungif collect2: error: ld returned 1 exit status make[1]: *** [libcf322683-513e-4570-a44b-7cdd7cae0de5.so] Error 1 make[1]: Leaving directory `/usr/local/epics/r3.14.12.5/extensions/src/edm/giflib/O.linux-x86_64' make: *** [install.linux-x86_64] Error 2 if I create a soft link to /usr/lib/x86_64-linux-gnu/libgif.a it shows the error: /usr/bin/g++ -o libcf322683-513e-4570-a44b-7cdd7cae0de5.so -shared -fPIC -Wl,-hlibcf322683-513e-4570-a44b-7cdd7cae0de5.so -L/usr/local/epics/r3.14.12.5/extensions/lib/linux-x86_64 -L/usr/l\
ib/x86_64-linux-gnu -Wl,-rpath,/usr/local/epics/r3.14.12.5/extensions/lib/linux-x86_64 -Wl,-rpath,/usr/lib/x86_64-linux-gnu -m64 gif.o reg_libcf322683-513e-4570-a44b-\ 7cdd7cae0de5.o -lEdmBase -lcfcaa62e-8199-11d3-a77f-00104b8742df -l114135a4-6f6c-11d3-95bc-00104b8742df -lXm -lXt -lXp -lXtst -lX11 -lpthread -ldl -lungif -lgif -lpthread -lreadline -l\ m -lrt -ldl -lgcc /usr/bin/ld: /usr/lib/x86_64-linux-gnu/libungif.a(dgif_lib.o): relocation R_X86_64_32S against `.rodata' can not be used when making a shared object; recompile with -fPIC /usr/lib/x86_64-linux-gnu/libungif.a: error adding symbols: Bad value collect2: error: ld returned 1 exit status make[1]: *** [libcf322683-513e-4570-a44b-7cdd7cae0de5.so] Error 1 make[1]: Leaving directory `/usr/local/epics/r3.14.12.5/extensions/src/edm/giflib/O.linux-x86_64' make: *** [install.linux-x86_64] Error 2 Has anyone installed edm on ubuntu14.04 64bit succesfully? Thanks a lot for your help.
Best wishes
Geyang 2016-12-16
| ANJ, 15 Dec 2016 |
Home
News
About
Talk
Base
Modules
Extensions
