1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Question about "Link A array too large"
To: lzf neu <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 28 Dec 2016 16:30:57 +0000
Have you checked the EPICS_CA_MAX_ARRAY_BYTES variable at your server and at your laptop?
Cheers,
Hugo
On Wed, Dec 28, 2016 at 12:15 PM lzf neu <[email protected]> wrote:
Hi all,
I want to read real-time dose value from the radiation monitor by using epics. The driver is modbus and asyn.
However,when starting epics ioc in server, I encounter a problem, the terminal displays something like the following information:
Link A array too large..
Link B array too large..
Link L array too large...
Segment fault(core dump)
The operation system used in server is fedora20 64bit. However, the same operation system and the same modbus and asyn driver works well in my laptop connected to the monitor.
Could you give me some suggestions to solve the problem, thanks in advanced.
Prev: RE: action buttons in CSS Iain Marcuson
Next: Choice button widget palak shimpee
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  <20162017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Question about "Link A array too large" Mark Rivers
ANJ, 29 Dec 2016 · Home · News · About · Talk · Base · Modules · Extensions ·
