1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Default value to field SCAN
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 3 Jan 2017 11:16:03 -0200
The OS is Linux, RHEL 6.
I think problem could be on ioc, I will check this,
Regards
Em 03-01-2017 11:11, Mark Rivers escreveu:
Those dbScan warnings are very unusual.  It makes me think there is something wrong with the timer system, because, for example the 0.5 second scan thread appears to be running much faster than 0.5 seconds, since it is averaging 0.00 seconds.  What operating system is this?
From: [email protected] [[email protected]] on behalf of Gabriel de Souza Fedel [[email protected]]
Sent: Tuesday, January 03, 2017 5:57 AM
To: [email protected]
Subject: Default value to field SCAN
When I create records and don't set the field SCAN, what is the default
value? There is an way to change this?
I'm having problems with a set of records without SCAN field that are
consuming a lot of CPU, and receiving this messages:
dbScan warning from '.2 second' scan thread:
         Scan processing averages 0,00 seconds (0,00 .. 0,02).
         Over-runs have now happened 283681 times in a row.
         To fix this, move some records to a slower scan rate.
dbScan warning from '.5 second' scan thread:
         Scan processing averages 0,00 seconds (0,00 .. 0,03).
         Over-runs have now happened 290049 times in a row.
dbScan warning from '.1 second' scan thread:
         Over-runs have now happened 278431 times in a row.
If i remove small choices from dbd file (.1, .2 and .5 seconds) solves
the problem. Apparently the records are being created with all SCAN
values...some idea to solve this?
Gabriel Fedel
Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
[email protected] | +55 (19) 3512 1226
www.lnls.cnpem.br
Gabriel Fedel
www.lnls.cnpem.br
Default value to field SCAN Gabriel de Souza Fedel
RE: Default value to field SCAN Mark Rivers
Prev: RE: Default value to field SCAN Mark Rivers
Next: RE: Asyn support Heesterman, Peter J
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Default value to field SCAN Andrew Johnson
