1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Installing areadetector on raspberry-pi2 OS raspbian pixels
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 5 Jan 2017 12:27:01 +0000
The problem is that you are also using a very old version of asyn.  You should update to a more recent version of asyn.  areaDetector requires the following modules from synApps
asyn
calc
sscan
autosave
busy
iocStats
I recommend that you get the latest released version of each of these.  They are all on Github:
https://github.com/epics-modules
From: [email protected] [[email protected]] on behalf of [email protected] [[email protected]]
Sent: Thursday, January 05, 2017 3:25 AM
To: [email protected]
I tried to follow INSTALL_GUIDE.md from github repository.
Now I am getting following error when trying to make.
pi@raspberrypi:~/Apps/epics/synApps_5_6/support/areaDetector-master $ make
make -C
/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport
install
make[1]: Entering directory
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport'
make -C ./configure install
make[2]: Entering directory
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/configure'
make -C O.linux-arm -f ../Makefile TOP=../.. \
    T_A=linux-arm install
make[3]: Entering directory
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/configure/O.linux-arm'
perl //home/pi/Apps/epics/base-3.14.12.6/bin/linux-arm/convertRelease.pl
checkRelease
make[3]: Leaving directory
make[2]: Leaving directory
make -C ./supportApp install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp'
make -C ./netCDFSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/netCDFSrc'
make -C O.linux-arm -f ../Makefile TOP=../../.. \
make[4]: Entering directory
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/netCDFSrc/O.linux-arm'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory
make -C ./jpegSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/jpegSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/jpegSrc/O.linux-arm'
make -C ./zlibSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/zlibSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/zlibSrc/O.linux-arm'
make -C ./tiffSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/tiffSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/tiffSrc/O.linux-arm'
make -C ./xml2Src install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/xml2Src'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/xml2Src/O.linux-arm'
make -C ./szipSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/szipSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/szipSrc/O.linux-arm'
make -C ./hdf5Src install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/hdf5Src'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/hdf5Src/O.linux-arm'
make -C ./nexusSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/nexusSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/supportApp/nexusSrc/O.linux-arm'
make[1]: Leaving directory
make -C /home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore
install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/configure'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/configure/O.linux-arm'
checkRelease
make -C ./ADApp install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp'
make -C ./Db install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp/Db'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp/Db/O.linux-arm'
make -C ./ADSrc install
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp/ADSrc'
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/ADApp/ADSrc/O.linux-arm'
/usr/bin/g++ -c  -D_GNU_SOURCE -D_DEFAULT_SOURCE             -DUNIX
-Dlinux     -O3 -g   -Wall           -fPIC -MMD -I. -I../O.Common -I. -I..
-I../../../include/os/Linux -I../../../include
-I//home/pi/Apps/epics/base-3.14.12.6/include/os/Linux
-I/home/pi/Apps/epics/synApps_5_6/support/asyn-4-18/include
-I/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADSupport/include/os/Linux
-I/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore/include
                 ../asynNDArrayDriver.cpp
../asynNDArrayDriver.cpp: In member function ‘virtual asynStatus
asynNDArrayDriver::readGenericPointer(asynUser*, void*)’:
../asynNDArrayDriver.cpp:492:20: error: ‘asynUser’ has no member named
‘timestamp’
         pasynUser->timestamp = myArray->epicsTS;
//home/pi/Apps/epics/base-3.14.12.6/configure/RULES_BUILD:221: recipe for
target 'asynNDArrayDriver.o' failed
make[4]: *** [asynNDArrayDriver.o] Error 1
//home/pi/Apps/epics/base-3.14.12.6/configure/RULES_ARCHS:61: recipe for
target 'install.linux-arm' failed
make[3]: *** [install.linux-arm] Error 2
//home/pi/Apps/epics/base-3.14.12.6/configure/RULES_DIRS:83: recipe for
target 'ADSrc.install' failed
make[2]: *** [ADSrc.install] Error 2
target 'ADApp.install' failed
make[1]: *** [ADApp.install] Error 2
target
'/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore.install'
failed
make: ***
[/home/pi/Apps/epics/synApps_5_6/support/areaDetector-master/ADCore.install]
Error 2
> Message: 1
> Date: Tue, 3 Jan 2017 14:21:24 +0000
> From: Mark Rivers <[email protected]>
>       pixels
> Message-ID:
>       <70AE7462E7AD054C89DCBA45343D499A65DFB148@CARSMAIL2.CARS.APS.ANL.GOV>
> Content-Type: text/plain; charset="us-ascii"
> You are trying to build areaDetector 1-8-beta1, which is a very old
> version of areaDetector.  It probably won't work on the Raspberry Pi, it
> was never tested with linux-arm.
> I suggest you get the latest version from Github.
> https://github.com/areaDetector
> The installation instructions are here:
> https://github.com/areaDetector/areaDetector/blob/master/INSTALL_GUIDE.md
> Mark
> Sent: Monday, January 02, 2017 10:18 PM
> Subject: Installing areadetector on raspberry-pi2 OS raspbian pixels
>    Hi,
>   Can anyone please suggest me steps to install areadetector
> module on raspberry-pi having OS raspbian pixels.
>      I tried to follow this link https://prjemian.github.io/epicspi/
> but while making areadetector module I am getting errors.
> Here are the response for make
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/configure/O.linux-arm'
> perl /usr/local/epics/base/bin/linux-arm/convertRelease.pl checkRelease
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/configure'
> make -C ./dac128VApp install
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp'
> make -C ./src install
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7/dac128VApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/dac128V-2-7'
> make -C /usr/local/epics/synApps_5_6/support/ip330-2-7 install
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/configure/O.linux-arm'
> make -C ./ip330App install
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App/src'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/ip330-2-7/ip330App/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/ipUnidig-2-9 install
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/configure/O.linux-arm'
> make -C ./ipUnidigApp install
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/ipUnidig-2-9/ipUnidigApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/love-3-2-5 install
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/configure/O.linux-arm'
> make -C ./loveApp install
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/loveApp/Db/O.linux-arm'
> make -C ./iocBoot install
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/iocBoot'
> make -C ./ioclove install
> '/home/pi/Apps/epics/synApps_5_6/support/love-3-2-5/iocBoot/ioclove'
> make[3]: Nothing to be done for 'install'.
> make -C /usr/local/epics/synApps_5_6/support/ip-2-13 install
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/configure/O.linux-arm'
> make -C ./ipApp install
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/ip-2-13/ipApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/optics-2-8-1 install
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/configure/O.linux-arm'
> make -C ./opticsApp install
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/optics-2-8-1/opticsApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/stream-2-5-1 install
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/configure/O.linux-arm'
> make -C ./streamDevice install
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/src'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/src/O.linux-arm'
> make -C ./srcSynApps install
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/srcSynApps'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/srcSynApps/O.linux-arm'
> make -C ./streamApp install
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/streamApp'
> '/home/pi/Apps/epics/synApps_5_6/support/stream-2-5-1/streamDevice/streamApp/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/modbus-2-3 install
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/configure/O.linux-arm'
> make -C ./modbusApp install
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/modbusApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/iocBoot'
> make -C ./iocTest install
> '/home/pi/Apps/epics/synApps_5_6/support/modbus-2-3/iocBoot/iocTest'
> make -C /usr/local/epics/synApps_5_6/support/vac-1-4 install
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/configure/O.linux-arm'
> make -C ./vacApp install
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/vacApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/iocBoot'
> make -C ./iocppc install
> '/home/pi/Apps/epics/synApps_5_6/support/vac-1-4/iocBoot/iocppc'
> make -C /usr/local/epics/synApps_5_6/support/softGlue-2-2 install
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/configure/O.linux-arm'
> make -C ./softGlueApp install
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/softGlue-2-2/softGlueApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/quadEM-2-6 install
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/configure/O.linux-arm'
> make -C ./quadEMApp install
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/quadEM-2-6/quadEMApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/delaygen-1-0-7 install
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/configure/O.linux-arm'
> make -C ./delaygenApp install
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/delaygenApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/iocBoot'
> make -C ./iocdelaygen install
> '/home/pi/Apps/epics/synApps_5_6/support/delaygen-1-0-7/iocBoot/iocdelaygen'
> make -C /usr/local/epics/synApps_5_6/support/camac-2-7 install
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/configure/O.linux-arm'
> make -C ./camacApp install
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/src/O.linux-arm'
> make -C ./devsrc install
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/devsrc'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/devsrc/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/camacApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/iocBoot'
> make -C ./iocxxx install
> '/home/pi/Apps/epics/synApps_5_6/support/camac-2-7/iocBoot/iocxxx'
> make -C /usr/local/epics/synApps_5_6/support/mca-7-1 install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/configure/O.linux-arm'
> make -C ./mcaApp install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp'
> make -C ./mcaSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/mcaSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/mcaSrc/O.linux-arm'
> make -C ./CanberraSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/CanberraSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/CanberraSupport/O.linux-arm'
> make -C ./CanberraSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/CanberraSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/CanberraSrc/O.linux-arm'
> make -C ./SISSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/SISSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/SISSrc/O.linux-arm'
> make -C ./RontecSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/RontecSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/RontecSrc/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/mcaApp/Db/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot'
> make -C ./iocCygwin install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot/iocCygwin'
> make -C ./iocRontec install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot/iocRontec'
> make -C ./iocVxWorks install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot/iocVxWorks'
> make -C ./iocLinux install
> '/home/pi/Apps/epics/synApps_5_6/support/mca-7-1/iocBoot/iocLinux'
> make -C /usr/local/epics/synApps_5_6/support/vme-2-8 install
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/configure/O.linux-arm'
> make -C ./vmeApp install
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp/src'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp/src/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp/Db'
> '/home/pi/Apps/epics/synApps_5_6/support/vme-2-8/vmeApp/Db/O.linux-arm'
> make -C /usr/local/epics/synApps_5_6/support/areaDetector-1-8beta1 install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/configure'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/configure/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/ADSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/ADSrc/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/netCDFSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/netCDFSrc/O.linux-arm'
> make -C ./cbfSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/cbfSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/cbfSrc/O.linux-arm'
> make -C ./prosilicaSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/prosilicaSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/prosilicaSupport/O.linux-arm'
> make -C ./tiffSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/tiffSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/tiffSupport/O.linux-arm'
> make -C ./hdf5Support install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/hdf5Support'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/hdf5Support/O.linux-arm'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/nexusSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/nexusSrc/O.linux-arm'
> make -C ./pvcamSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/pvcamSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/pvcamSupport/O.linux-arm'
> make -C ./perkinElmerSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/perkinElmerSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/perkinElmerSupport/O.linux-arm'
> make -C ./magickSupport install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/magickSupport'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/magickSupport/O.linux-arm'
> make -C ./pluginSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/pluginSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/pluginSrc/O.linux-arm'
> make -C ./simDetectorSrc install
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/simDetectorSrc'
> '/home/pi/Apps/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/simDetectorSrc/O.linux-arm'
> make[4]: *** No rule to make target
> '../../../lib/linux-arm/libGraphicsMagick.a', needed by 'simDetectorApp'.
> Stop.
> /usr/local/epics/base/configure/RULES_ARCHS:61: recipe for target
> /usr/local/epics/base/configure/RULES_DIRS:83: recipe for target
> 'simDetectorSrc.install' failed
> make[2]: *** [simDetectorSrc.install] Error 2
> '/usr/local/epics/synApps_5_6/support/areaDetector-1-8beta1.install'
> failed
> make: ***
> [/usr/local/epics/synApps_5_6/support/areaDetector-1-8beta1.install] Error
> 2
> With Best Regards,
> Avanish Ojha
> Message: 2
> Date: Tue, 3 Jan 2017 14:36:00 +0000
> From: "Kasemir, Kay" <[email protected]>
> To: lzf neu <[email protected]>
> Cc: "[email protected]" <[email protected]>
> Subject: Re: Question about CSS Data Browser plot
> Message-ID: <[email protected]>
> Content-Type: text/plain; charset="utf-8"
> Hi:
> This  type of behavior can happen when your IOCs don?t have the correct
> time.
> Check if ?camonitor ..? reports good time stamps for the PVs from your
> IOCs.
> -Kay
> On Dec 29, 2016, at 11:06 AM, lzf neu
> <[email protected]<mailto:[email protected]>> wrote:
> hi all,
> When added pv name to Data Browser plot window, the plot line vs. time
> showed the right curve, but immediately changed into straight one which is
> not the right display. The line should fluctuate vs time. The time span I
> set is 1 hour. If I increase the time span, the line is still a straight
> one.
> however, the exported data is right from data browser plot and fluctuate
> vs time.
> I wonder what is wrong with my settings. The operation system is
> fedora25-64bit and CSS is unzipped from
> sns-css-4.1.1-linux.gtk.x86_64.zip.
> I have attatched the plot in the attatchment. Thanks in advance.
> <aaa.png>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20170103/32e47f9e/attachment.html>
> Message: 3
> Date: Tue, 3 Jan 2017 15:01:48 +0000
> From: <[email protected]>
> To: <[email protected]>
> Subject: EPICS core development role at Diamond Light Source
> Message-ID: <AD1BB40A7457F5419F99609AD5B4CA92BA51253D@exchmbx03>
> Hello All,
> Diamond light source is one of the larger EPICS installations, having
> deployed EPICS for machine, photon beamline and detector control. As
> result we have a strong interest in the ongoing and successful development
> of EPICS and so have been actively contributing to the core development of
> EPICS at number of levels; including participating in the development of
> EPICS Version 4. We now have a vacancy for a developer to work on aspects
> of core EPICS developments, including EPICS Version 4. The role is
> expected to work closely with the other EPICS developers in defining
> future direction and taking on agreed work packages.  It will also be
> expected to represent Diamond in these developments and to contribute to
> developers' meetings and workshops. In undertaking this, there is full
> support from Diamond for travel etc.
> If this is a role which is of interest and you would like to discuss
> further, please feel free to contact myself.
> This vacancy is now listed on
> http://www.diamond.ac.uk/Careers/Vacancies/All/0114_16_NH.html with a
> closing date of 31/1/17.
> Regards.
> Mark Heron
> This e-mail and any attachments may contain confidential, copyright and or
> privileged material, and are for the use of the intended addressee only.
> If you are not the intended addressee or an authorised recipient of the
> addressee please notify us of receipt by returning the e-mail and do not
> use, copy, retain, distribute or disclose the information in or attached
> to the e-mail.
> Any opinions expressed within this e-mail are those of the individual and
> not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for any
> damage which you may sustain as a result of software viruses which may be
> transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in England
> and Wales with its registered office at Diamond House, Harwell Science and
> Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom
> A non-text attachment was scrubbed...
> Type: application/ms-tnef
> Desc: not available
> URL:
> <http://mailman.aps.anl.gov/pipermail/tech-talk/attachments/20170103/ae94e34c/attachment.bin>
> Tech-talk mailing list [email protected]
> https://mailman.aps.anl.gov/mailman/listinfo/tech-talk
> End of Tech-talk Digest, Vol 11, Issue 5
RE: Installing areadetector on raspberry-pi2 OS raspbian pixels avanish
Prev: Re: Default value to field SCAN Dirk Zimoch
Next: multiple include not supprted with EPICS 3.15.2 haquin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Installing areadetector on raspberry-pi2 OS raspbian pixels avanish
