Subject: Re: ca_search() and "preemptive callback"
To: <[email protected]>
Date: Thu, 5 Jan 2017 12:53:51 -0600
Hi Mike,
On 01/05/2017 12:33 PM, Michael Westfall wrote:
> We are converting our legacy systems from EPICS 3.13/vxWorks to EPICS
> 3.14/RTEMS,
> I have an IOC that calls
> *SEVCHK( ca_search(buf, &id), "ca_search failed\n");*
Where is this code? What thread is going to execute it?
I suspect you're going to have to rewrite some of that subsystem, but
we'll need rather more information about what it's trying to do to be
able to give you much help.
- Andrew
> but it results in the following error:
> *dbContext: preemptive callback required for direct in
> memory interfacing of CA channels to the DB.
> CA.Client.Exception...............................................
>     Warning: "Not supported by attached service"
>     Context: "ca_search failed
>     Source File: ../caLogDataDriver.c line 119
>     Current Time: Thu Jan 05 2017 18:02:41.367850828*
> OK, so I insert this first:
> *SEVCHK(ca_context_create(ca_enable_preemptive_callback),
> "caInitLogSetup() calling ca_context_create()");*
> But now I get this
> *CA.Client.Exception...............................................
>     Error: "Preemptive callback not enabled - additional threads may not
> join context"
>     Context: "caInitLogSetup() calling ca_context_create()"
>     Source File: ../caLogDataDriver.c line 106
>     Current Time: Thu Jan 05 2017 17:41:58.248806684
> What am I missing? Do I need to supply a callback function first? The
> Channel Access documentation seems a bit sparse in this regard...
> Mike Westfall
> Control Systems Software Engineer
Re: ca_search() and "preemptive callback" Michael Westfall
Prev: ca_search() and "preemptive callback" Michael Westfall
Next: Re: ca_search() and "preemptive callback" Michael Westfall
