Subject: RE: synApps_5_8 build error
To: "Abdalla Ahmad" <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 8 Jan 2017 13:49:35 +0000
If you change /home/control/epics/support/synApps_5_8/support/configure/RELEASE to define
SUPPORT=/home/control/epics/support/synApps_5_8/support/
EPICS_BASE=/home/control/epics/base-3.14.12.3
does that fix the problem?  Maybe it is not picking up the environment variables correctly.
From: [email protected] [[email protected]] on behalf of Abdalla Ahmad [[email protected]]
Sent: Sunday, January 08, 2017 12:26 AM
To: [email protected]
Subject: synApps_5_8 build error
Hi
I downloaded the mentioned version of synApps and I modified SUPPORT and EPICS_BASE in configure/RELEASE file as:
SUPPORT=$(SYNAPPS_SUPPORT)
EPICS_BASE=$(ENV_EPICS_BASE)
These variables are already defined in .bashrc and exported. The list of modules for our site is
Asyn
Allen_Bradlley
Autosave
Busy (Added to resolve a similar error at compiling asyn )
Calc
IP
IPAC
Motor
SNCSEQ
SSCAN
STREAM
Executing 'make release' then make gives the following:
Definition of SNCSEQ conflicts with SUPPORT support.
In this application a RELEASE file defines
                SNCSEQ = /home/control/epics/support/synApps_5_8/support/seq-2-2-1
but SUPPORT at /home/control/epics/support/synApps_5_8/support defines
                SNCSEQ = /seq-2-2-1
Definition of EPICS_BASE conflicts with SUPPORT support.
                EPICS_BASE = /home/control/epics/base-3.14.12.3
                EPICS_BASE =
Definition of SUPPORT conflicts with SUPPORT support.
                SUPPORT = /home/control/epics/support/synApps_5_8/support
                SUPPORT =
I have no clue of where these wrong definitions are. I thought of giving hard coded paths for the aforementioned variables instead of env ones and the build works fine. I believe on synApps 5.6 we did not face that error.
Best Regards,
Abdalla Ahmad
Control Engineer
SESAME
Allan, Jordan.
Tel: (+962-5) 3511348 , ext. 265
Fax: (+962-5) 3511423
Mob: (+962-7)88183296
www.sesame.org.jo<http://www.sesame.org.jo/>
RE: synApps_5_8 build error Abdalla Ahmad
Prev: synApps_5_8 build error Abdalla Ahmad
Next: RE: synApps_5_8 build error Abdalla Ahmad
