1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Multiple OS Build
To: "'Hugo Slepicka'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 9 Jan 2017 17:44:31 +0000
Hi Hugo,
I have done this by just using a few new files and soft links in base/configure/os.
So in addition to linux-x86 and linux-x86_64 I am building for 3 additional Linux architectures which I call linux-x86_64-gcc42, linux-x86-gcc43, and linux-x86_64-rhel6
lrwxrwxrwx 1 epics epics 26 Dec  9  2015 CONFIG.Common.linux-x86_64-rhel6 -> CONFIG.Common.linux-x86_64
lrwxrwxrwx 1 epics epics 26 Dec  9  2015 CONFIG.linux-x86_64-rhel6.Common -> CONFIG.linux-x86_64.Common
lrwxrwxrwx 1 epics epics 32 Dec  9  2015 CONFIG.linux-x86_64-rhel6.linux-x86_64-rhel6 -> CONFIG.linux-x86_64.linux-x86_64
lrwxrwxrwx 1 epics epics   23 May  7  2015 CONFIG.Common.linux-x86-gcc43 -> CONFIG.Common.linux-x86
lrwxrwxrwx 1 epics epics   26 May  6  2015 CONFIG.Common.linux-x86_64-gcc42 -> CONFIG.Common.linux-x86_64
lrwxrwxrwx 1 epics epics   23 May  7  2015 CONFIG.linux-x86-gcc43.Common -> CONFIG.linux-x86.Common
lrwxrwxrwx 1 epics epics   26 May  7  2015 CONFIG.linux-x86-gcc43.linux-x86-gcc43 -> CONFIG.linux-x86.linux-x86
lrwxrwxrwx 1 epics epics   26 May  6  2015 CONFIG.linux-x86_64-gcc42.Common -> CONFIG.linux-x86_64.Common
lrwxrwxrwx 1 epics epics   32 May  6  2015 CONFIG.linux-x86_64-gcc42.linux-x86_64-gcc42 -> CONFIG.linux-x86_64.linux-x86_64
-rw-r--r-- 1 epics epics 1828 May  7  2015 CONFIG_SITE.Common.linux-x86-gcc43
-rw-r--r-- 1 epics epics 1833 May  6  2015 CONFIG_SITE.Common.linux-x86_64-gcc42
For files which need to be different from the distribution files I create new files, while for those that just need a different name I use soft links.
In my case those additional architectures are on different computers that all share the same file system.  I just change the login files on those computers to define EPICS_HOST_ARCH as appropriate.
From: [email protected] [mailto:[email protected]] On Behalf Of Hugo Slepicka
Sent: Monday, January 09, 2017 11:37 AM
To: [email protected]
Subject: Multiple OS Build
Hi All,
I would like some input from the community regarding the organization of EPICS build for multiple OS targets (not cross-compiling), e.g. RHEL (5, 6, 7), Debian and other flavors available to coexist in a shared directory structure.
How is the community handling cases similar to rhel7-x86_64 versus rhel6-x86_64 given that "EPICS_HOST_ARCH" returns "linux-x86_64" for both?
One possible solutions would be to use something like:
       <shared_path>/<os_version>/base/.../<EPICS_HOST_ARCH>/...
       - where os_version would be: rhel5, rhel6, deb7, deb8, etc.
Another solution would be to apply a local patch to the EPICS building system to return a specific value for EPICS_HOST_ARCH including the <os_version>, e.g. rhel6-x86_64, resulting in something like this:
       <shared_path>/base/.../<NEW_EPICS_HOST_ARCH>/...
Hugo
Multiple OS Build Hugo Slepicka
Prev: Multiple OS Build Hugo Slepicka
Next: Re: Multiple OS Build Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
