1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: DSO missing from command line Error in Ubuntu 16.04 LTS
To: "EPICS Tech-Talk" <[email protected]>
Cc: Anindya Roy <[email protected]>
Date: Tue, 10 Jan 2017 17:44:38 +0530
I am getting an abnormal error while building an application in EPICS in ubuntu 16.04 x86 platform. I could successfully build EPICS base 3.15.5 and asysn 4-30 without error. But get the following error:
make[3]: Entering directory '/home/epics/base-3.15.5/asyn4-30/tcpscc/tcpsccApp/src/O.linux-x86'
/usr/bin/g++ -o tcpscc  -L/home/epics/base-3.15.5/asyn4-30/tcpscc/lib/linux-x86 -Wl,-rpath,/home/epics/base-3.15.5/asyn4-30/tcpscc/lib/linux-x86           -rdynamic -m32            tcpscc_registerRecordDeviceDriver.o tcpsccMain.o    -ldevtcpscc -lasyn
/usr/bin/ld: tcpscc_registerRecordDeviceDriver.o: undefined reference to symbol 'iocshRegisterCommon'
/home/epics/base-3.15.5/asyn4-30/tcpscc/lib/linux-x86/libdbCore.so.3.15.5: error adding symbols: DSO missing from command line
collect2: error: ld returned 1 exit status
/home/epics/base-3.15.5/configure/RULES_BUILD:201: recipe for target 'tcpscc' failed
make[3]: *** [tcpscc] Error 1
make[3]: Leaving directory '/home/epics/base-3.15.5/asyn4-30/tcpscc/tcpsccApp/src/O.linux-x86'
/home/epics/base-3.15.5/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86' failed
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory '/home/epics/base-3.15.5/asyn4-30/tcpscc/tcpsccApp/src'
/home/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make[1]: *** [src.install] Error 2
make[1]: Leaving directory '/home/epics/base-3.15.5/asyn4-30/tcpscc/tcpsccApp'
/home/epics/base-3.15.5/configure/RULES_DIRS:84: recipe for target 'tcpsccApp.install' failed
make: *** [tcpsccApp.install] Error 2
I have tried with different version of epics and asyn, but the error persists. Is it related to OS?
शांतनु साहू / Shantonu Sahoo
Re: DSO missing from command line Error in Ubuntu 16.04 LTS Johnson, Andrew N.
Prev: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Messaoud Harfouche
Next: Re: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Looking for someone to help building the control system of XAFS/XRF beamline at SESAME Mark Clift
Next: Re: DSO missing from command line Error in Ubuntu 16.04 LTS Johnson, Andrew N.
