Subject: Re: CA server bind failure on Windows
To: EPICS Tech Talk <[email protected]>
Date: Mon, 16 Jan 2017 13:59:51 +0100
On 15.01.2017 19:01, Ralph Lange wrote:
> Hi Ben,
> On Sun, Jan 15, 2017 at 3:37 AM, Ben Franksen <
> [email protected]> wrote:
>> Am 12.01.2017 um 19:04 schrieb [email protected]:
>> [...] suggests another application/service might have bound to the port
>>> already with SO_EXCLUSIVEADDRUSE and this appears to be the situation
>>> (the National Instruments network variables server process in this
>>> case).
>> This is very nasty behaviour on part of NI. The CA ports 5064 and 5065
>> are registered with the IANA and officially belong to Channel Access
>> (both UDP and TCP), see
>> https://www.iana.org/assignments/service-names-port-numbers/service-names-
>> port-numbers.txt.
>> IMO you should file a complaint with NI; they should change their
>> default port to some unregistered port, perhaps they want to register
>> their protocol with IANA under another port number, but simply hijacking
>> an existing registered port is not acceptable.
> Careful...
> NI's LabVIEW network variables server has a plugin that contains their
> implementation of the Channel Access server, see
> http://www.ni.com/white-paper/13865/en/. While their CA server has a couple
> of flaws and issues and doesn't fully behave like the EPICS CA servers
> (e.g. by presumably using SO_EXCLUSIVEADDRUSE), using the Channel Access
> ports for Channel Access is definitely legitimate and recommended.
Oops. Sorry... (to NI, mostly).
Cheers
Ben
"Make it so they have to reboot after every typo." ― Scott Adams
Attachment: signature.asc
Description: OpenPGP digital signature
CA server bind failure on Windows freddie.akeroyd
Re: CA server bind failure on Windows Ben Franksen
Re: CA server bind failure on Windows Ralph Lange
Prev: Re: Asyn and devices with changing register map Dirk Zimoch
Next: Support for Rigol DSA815 spectrum analyzer? [RF-128] Konrad, Martin
Prev: Re: CA server bind failure on Windows Ralph Lange
Next: Re: CA server bind failure on Windows Andrew Johnson
