Thank you Mark, I tried commands as you suggested and following is the result ~> ping 192.168.127.254 PING 192.168.127.254 (192.168.127.254) 56(84) bytes of data. 64 bytes from 192.168.127.254: icmp_seq=1 ttl=255 time=0.857 ms 64 bytes from 192.168.127.254: icmp_seq=2 ttl=255 time=0.831 ms 64 bytes from 192.168.127.254: icmp_seq=3 ttl=255 time=0.823 ms 64 bytes from 192.168.127.254: icmp_seq=4 ttl=255 time=0.808 ms 64 bytes from 192.168.127.254: icmp_seq=5 ttl=255 time=0.714 ms 64 bytes from 192.168.127.254: icmp_seq=6 ttl=255 time=0.757 ms 64 bytes from 192.168.127.254: icmp_seq=7 ttl=255 time=0.766 ms 64 bytes from 192.168.127.254: icmp_seq=51 ttl=255 time=0.840 ms 64 bytes from 192.168.127.254: icmp_seq=52 ttl=255 time=0.723 ms 64 bytes from 192.168.127.254: icmp_seq=53 ttl=255 time=0.857 ms 64 bytes from 192.168. ______________________________ ^C --- 192.168.127.254 ping statistics --- 54 packets transmitted, 54 received, 0% packet loss, time 53000ms rtt min/avg/max/mdev = 0.691/0.783/0.857/0.054 ms telnet 192.168.127.254:4001 telnet: 192.168.127.254:4001: Name or service not known :~> telnet 192.168.127.254 Trying 192.168.127.254... telnet: connect to address 192.168.127.254: Connection timed out Also I attached screenshot of the configuration of Ethernet port which is connected to moxa. I am weak in Networking so thare are chances for mistake in configuration. thanks On Wed, Jan 18, 2017 at 5:28 PM, Mark Rivers <[email protected]> wrote: Hi Sunny, Attachment:
Screenshot from 2017-01-18 17-52-54.png Attachment:
Screenshot from 2017-01-18 17-45-31.png Attachment:
| ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
