Hi Andrew,
I can confirm the patch works fine. Though Windows bind() can return 10 possible error codes, on closer inspection anything other than EACCES or EADDRINUSE indicate something is probably wrong with either the socket descriptor itself or the network interface being connected to and so a bind retry is unlikely to lead anywhere. Thus the more conservative approach should still cover all eventualities.
Freddie
-----Original Message-----
Sent: 18 January 2017 18:24
To: Akeroyd, Freddie (STFC,RAL,ISIS)
Cc: [email protected]
Subject: Re: CA server bind failure on Windows
Hi Freddie,
On 01/12/2017 12:04 PM, [email protected] wrote:
> I've had instances of both an IOC and a CAS being unable to create a
> channel access port. The servers attempt to bind to the usual channel
> access server port number, but rather than EADDRINUSE being returned
> on failure they are seeing EACCES.
Ralph suggested that we adopt a slightly more conservative approach to fixing the issue, could you confirm this patch please.
- Andrew
Arguing for surveillance because you have nothing to hide is no different than making the claim, "I don't care about freedom of speech because I have nothing to say." -- Edward Snowdon
- CA server bind failure on Windows freddie.akeroyd
- Re: CA server bind failure on Windows Andrew Johnson
Re: Problem compiling StreamDevice on Visual Studio 2015 Dirk Zimoch
Re: Problem NFS mounting Centos 7 file systems from vxWorks 5.5 Andrew Johnson
<2017>
2025
2026
Problems with seq 2.2.4 on Windows Mark Rivers
<2017>
2025
2026
