1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Emulating the use of Global VxWorks Variables in OSI
To: Talk EPICS Tech <[email protected]>
Date: Fri, 20 Jan 2017 10:00:46 -1000
Greetings,
I have a telescope system (our 8 meter primary mirror) which employs DTYP=vxWorks Variable in a ubiquitous manner.
In rtems this is not possible, so we're researching a refactor of the design. I've considered these two options below:
* a new device support module which exports key variables and updates them with sufficient scan rates. Our mirror loops are generally slow (as fast as 1 second).
* Use the SNCSEQ to keep C code and epics records synchronized.
Has anyone done something similar?
Thank you,
-Matt
Re: Emulating the use of Global VxWorks Variables in OSI Andrew Johnson
Prev: Re: Table properties in CSS BOY Kasemir, Kay
Next: Re: Emulating the use of Global VxWorks Variables in OSI Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
