I quickly checked the code and found the following limitations:
1. The driver uses vxWorks functions instead of EPICS OSI functions.
2. The configure function can only be called from the vxWorks shell, not
from iocsh.
3. The Makefile uses the PSI build system and is not compatible with the
standard EPICS build system. You would have to write your own Makefile.
4. Parts of the code are under copyright by Tews (basically ioctl, isr
and init). Publishing it may be illegal. I don't know if the source was
under some license. The original files are on a Floppy which I cannot
read any more. At least the original Tews driver documentation
explicitly forbids unauthorized reproduction of the documentation. The
files themselves claim:
Copyright (c) 1996
Tews Datentechnik GmbH
Maybe if you can convincingly assure that you have already a copy of the
original Tews "TIP866 VxWorks Device Driver", I can give you my EPICS
enabled version (basically a configure function which call some drvIpac
and asyn functions).
Dirk
On 26.01.2017 09:15, Dirk Zimoch wrote:
On 25.01.2017 18:11, Gary Croke wrote:
Does anyone have a driver for the TEWS TIP866 (or TIP865) serial IP
module?
Gary
Hi Gary,
I have one. I will put it on github...
Dirk
- TEWS TIP866 serial IP Gary Croke
- Re: TEWS TIP866 serial IP Dirk Zimoch
Re: TEWS TIP866 serial IP Ralph Lange
<2017>
2025
2026
<2017>
2025
2026
