Subject: RE: epics 3.12.4 rebuild
To: "[email protected]" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 29 Jan 2017 01:12:39 +0000
HI Freddie,
   That did help, thanks. I also had to change isnan(0) to isnan(0.0) in epicsCalcTest.cpp; similarly for isinf(0.0). Then the build completed.
Pete.
Sent: Saturday, January 28, 2017 4:37 PM
To: [email protected]; Siddons, David; [email protected]
If it is not possible/convenient to upgrade, you could try this fix on your existing setup  http://www.aps.anl.gov/epics/tech-talk/2016/msg00754.php
Freddie
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Mark Rivers
Sent: 28 January 2017 20:49
To: D Peter Siddons; EPICS
I would suggest trying 3.14.12.6 or 3.15.5.  We are now running 3.15.5 on our beamlines and we are happy with it.  We are running gcc 4.8.5 not 5.4.0.
From: [email protected] [[email protected]] on behalf of D Peter Siddons [[email protected]]
Sent: Saturday, January 28, 2017 1:54 PM
To: EPICS
Subject: epics 3.12.4 rebuild
I just had a reason to re-compile my EPICS distribution, and it failed. It is 3.14.12.4, and I am running Ubunti 16.04 LTS, using gcc version 5.4.0. Here is the error:
make[3]: Entering directory '/home/peter/epics/base-3.14.12.4/src/libCom/test/O.linux-x86_64'
/usr/bin/g++ -c  -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS -D_XOPEN_SOURCE=500           -D_X86_64_  -DUNIX  -D_BSD_SOURCE -Dlinux  -D_REENTRANT   -O3 -g   -Wall      -m64      -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux -I../../../../include        ../epicsCalcTest.cpp
../epicsCalcTest.cpp: In function 'int main(int, char**)':
../../../../include/os/Linux/epicsMath.h:22:21: error: non-floating-point argument in call to function '__builtin_isfinite'
 #  define finite(x) isfinite(x)
../epicsCalcTest.cpp:102:40: note: in definition of macro 'testExpr'
 #define testExpr(expr) testCalc(#expr, expr);
../epicsCalcTest.cpp:314:14: note: in expansion of macro 'finite'
     testExpr(finite(0));
../epicsCalcTest.cpp:328:14: error: non-floating-point argument in call to function '__builtin_isinf_sign'
     testExpr(isinf(0));
../epicsCalcTest.cpp:332:14: error: non-floating-point argument in call to function '__builtin_isnan'
     testExpr(isnan(0));
../../../../configure/RULES_BUILD:209: recipe for target 'epicsCalcTest.o' failed
make[3]: *** [epicsCalcTest.o] Error 1
make[3]: Leaving directory '/home/peter/epics/base-3.14.12.4/src/libCom/test/O.linux-x86_64'
../../../configure/RULES_ARCHS:63: recipe for target 'install.linux-x86_64' failed
make[2]: *** [install.linux-x86_64] Error 2
Any ideas?
epics 3.12.4 rebuild D Peter Siddons
RE: epics 3.12.4 rebuild Mark Rivers
RE: epics 3.12.4 rebuild freddie.akeroyd
Prev: RE: epics 3.12.4 rebuild freddie.akeroyd
Next: Question about CSS plot refresh lzf neu
