Dear all,
I have a IOC using synApps 5.8 (for the "transform" record) and sequencer 2.2.4.
I cloned my IOC from XXX reference IOC in synApps as suggested by documentation.
If I set SNCSEQ variable pointing to my sequencer 2.2.4 installation on top of
my IOC RELEASE file, it gets ignored and my state machines are compiled with the
sequencer included in synApps (2.2.1). If I set SNCSEQ at the bottom of RELEASE,
this error message is printed and compilation stops:
make[2]: Entering directory
'/home/lcavalli/Documents/Progetti/[...]/StateMachineExec/configure/O.linux-
x86_64'
perl /opt/epics/base/bin/linux-x86_64/convertRelease.pl checkRelease
Definition of SNCSEQ conflicts with SUPPORT support.
In this application a RELEASE file defines
SNCSEQ = /opt/epics/modules/seq-2.2.4
but SUPPORT at /opt/epics/support defines
SNCSEQ = /opt/epics/support/seq-2-2-1
Definition of SNCSEQ conflicts with SSCAN support.
but SSCAN at /opt/epics/support/sscan-2-10-1 defines
Definition of SNCSEQ conflicts with CALC support.
but CALC at /opt/epics/support/calc-3-4-2-1 defines
Definition of SNCSEQ conflicts with ASYN support.
but ASYN at /opt/epics/support/asyn-4-26 defines
Definition of SNCSEQ conflicts with XXX support.
but XXX at /opt/epics/support/xxx-5-8-3 defines
/opt/epics/base/configure/RULES_BUILD:171: recipe for target 'checkRelease'
failed
make[2]: *** [checkRelease] Error 1
make[2]: Leaving directory
x86_64'
/opt/epics/base/configure/RULES_ARCHS:64: recipe for target 'install.linux-
x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory
'/home/lcavalli/Documents/Progetti/[...]/StateMachineExec/configure'
/opt/epics/base/configure/RULES_DIRS:87: recipe for target 'configure.install'
failed
make: *** [configure.install] Error 2
[lcavalli@cavalli StateMachineExec]$
Setting SNCSEQ in my src/Makefile works, but is it the correct approach?
Is it possible to make synApps (and its sequencer installation used internally)
and an external sequencer installation coexist?
Thanks for your help,
Luca
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
- Re: synApps and external sequencer installation Benjamin Franksen
- RE: synApps and external sequencer installation Mark Rivers
Announcing the Transient Recorder Framework ambroz . bizjak
<2017>
2025
2026
<2017>
2025
2026
