1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: problem compiling edm
To: Mark Rivers <[email protected]>, Pierrick Hanlet <[email protected]>, "Sinclair, John William" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 02 Feb 2017 21:25:48 +0000
Hi Pierrick,
I also had the problem with the fonts at EDM.
What did the trick for me was:
sudo xset fp+ /usr/share/X11/fonts/75dpi
Just the fonts.conf at /etc/X11/xorg.conf was not enough.
Cheers,
Hugo
On Thu, Feb 2, 2017 at 1:10 PM Mark Rivers <[email protected]> wrote:
Certainly for medm the default fonts installed on RHEL 7 are not sufficient.  The instructions on how to install additional fonts here is required:
http://aps.anl.gov/epics/extensions/medm/index.php
Perhaps edm needs the same packages?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Pierrick Hanlet
Sent: Thursday, February 02, 2017 2:38 PM
To: Sinclair, John William; [email protected]
Thank you John,
That did the trick.
Now I need to revisit the fonts issue.  There's an old message of adding
Fonts.conf to /etc/X11/xorg.conf, but that doesn't appear to work with
this newer os.
Perhaps the problem is that I've not been able to find the "unscaled"
fonts.  Any ideas?
Thanks again,
Pierrick
On 02/02/2017 04:12 PM, Sinclair, John William wrote:
> I believe I added the following to the makefile locally for newer versions of gcc:
>    USR_CXXFLAGS += -fpermissive -Wno-narrowing -Wno-write-strings -Wno-unused-but-set-variable
> John Sinclair
> Sent: Thursday, February 02, 2017 9:16 AM
> To: [email protected]
> Subject: problem compiling edm
> I've a new pc on which I'm running Fedora release 25.  I'm using base 3.15.5.
> I'm attempting to build edm, but whilst attempting to compile, I get:
> make[2]: Entering directory
> '/home/epics/epicsDEV/extensions/src/edm/lib/O.linux-x86_64'
> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_  -DUNIX
> -Dlinux     -O3 -g   -Wall -DSINGLE_THREADED=1 -D__epics__=1
> -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I..
> -I../../../../include/edm/compiler/gcc
> -I../../../../include/edm/os/Linux -I../../../../include/edm -I/home/epics/epicsDEV/base/include/compiler/gcc
> -I/home/epics/epicsDEV/base/include/os/Linux
> -I/home/epics/epicsDEV/extensions/include        -I../../util
> -I../../lib -I/usr/include -I/usr/include    -c ../cursor.cc
> ../cursor.cc: In member function ‘void cursorClass::create(Display*, Window, Colormap)’:
> ../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing]
>       0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
> ../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing] and many more lines of the same.
> I can't find this problem in tech-talk, nor with a web search. Has anyone run into this problem and if so, how did you resolve it?
> Many thanks,
> Pierrick
problem compiling edm Pierrick Hanlet
Re: problem compiling edm Pierrick Hanlet
RE: problem compiling edm Mark Rivers
Prev: RE: problem compiling edm Mark Rivers
Next: RE: problem compiling edm Sinclair, John William
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
