1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: edm, Fedora 25, and Wayland
To: "Sinclair, John William" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 3 Feb 2017 09:51:27 +0000
Hi John,
I've changed the subject line of this thread to reflect the new issue (the edm compilation is solved, thank you).
The fonts problem may be deeper. Fedora 25 has, by default uses Wayland, instead of X, for its display server.
If edm is tied to X, do I/can I run 2 display servers?
Thank you,
Pierrick
On 02/02/2017 09:54 PM, Sinclair, John William wrote:
become root...
dnf install xorg-x11-fonts-75dpi
dnf install xorg-x11-fonts-ISO8859-1-75dpi
Use the version 5 font file.
Version 3 is described in https://ics-web.sns.ornl.gov/edm/eum.html#id2503129 .
Version 4 adds substitutions for all instances of a font spec. See https://ics-web.sns.ornl.gov/edm/log/show.php?mon=Apr&theDay=16&year=2012 .
Version 5 adds substitutions for single instances of a font spec. See https://ics-web.sns.ornl.gov/edm/log/show.php?mon=Jul&theDay=22&year=2013 .
Before Redhat released the liberation fonts, the scalable Helvetica font that shipped with their distribution rendered 16 point fonts smaller than it should have been. Liberation san-serif 16 point would not fit in objects that were sized based on the contents of text.  Version 5 allows a font rendering adjustment that can be used as a temporary fix (until some poor developer takes the time to change 10000 screens).
John
-----Original Message-----
Sent: Thursday, February 02, 2017 3:38 PM
To: Sinclair, John William; [email protected]
Subject: Re: problem compiling edm
Thank you John,
That did the trick.
Now I need to revisit the fonts issue.  There's an old message of adding Fonts.conf to /etc/X11/xorg.conf, but that doesn't appear to work with this newer os.
Perhaps the problem is that I've not been able to find the "unscaled"
fonts.  Any ideas?
Thanks again,
Pierrick
On 02/02/2017 04:12 PM, Sinclair, John William wrote:
I believe I added the following to the makefile locally for newer versions of gcc:
    USR_CXXFLAGS += -fpermissive -Wno-narrowing -Wno-write-strings
-Wno-unused-but-set-variable
John Sinclair
[mailto:[email protected]] On Behalf Of Pierrick Hanlet
Sent: Thursday, February 02, 2017 9:16 AM
To: [email protected]
Subject: problem compiling edm
I've a new pc on which I'm running Fedora release 25.  I'm using base 3.15.5.
I'm attempting to build edm, but whilst attempting to compile, I get:
make[2]: Entering directory
'/home/epics/epicsDEV/extensions/src/edm/lib/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_  -DUNIX
-Dlinux     -O3 -g   -Wall -DSINGLE_THREADED=1 -D__epics__=1
-mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I..
-I../../../../include/edm/compiler/gcc
-I../../../../include/edm/os/Linux -I../../../../include/edm
-I/home/epics/epicsDEV/base/include/compiler/gcc
-I/home/epics/epicsDEV/base/include/os/Linux
-I/home/epics/epicsDEV/extensions/include        -I../../util
-I../../lib -I/usr/include -I/usr/include    -c ../cursor.cc
../cursor.cc: In member function ‘void cursorClass::create(Display*, Window, Colormap)’:
../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing]
       0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
../cursor.cc:82:50: error: narrowing conversion of ‘224’ from ‘int’ to ‘char’ inside { } [-Wnarrowing] and many more lines of the same.
I can't find this problem in tech-talk, nor with a web search. Has anyone run into this problem and if so, how did you resolve it?
Many thanks,
Pierrick
RE: edm, Fedora 25, and Wayland Sinclair, John William
problem compiling edm Pierrick Hanlet
Re: problem compiling edm Pierrick Hanlet
RE: problem compiling edm Sinclair, John William
Prev: RE: Question : What kind of OPI is best? Mark Rivers
Next: RE: Question : What kind of OPI is best? Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: problem compiling edm Sinclair, John William
Next: RE: edm, Fedora 25, and Wayland Sinclair, John William
