1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Command omsMAXnetConfig not found
To: Kevin Peterson <[email protected]>
Cc: [email protected]
Date: Fri, 3 Feb 2017 10:27:55 -0800
OK, thanks for the heads up.
On Feb 3, 2017 9:41 AM, "Kevin Peterson" <[email protected]> wrote:
David,
You may run into problems caused by noise on the limit lines of the
motors controlled by the MAXnet.  I incorrectly assumed it had the same
internal filters as the MAXv.  Here is the info I received from OMS on
the subject:
  "The MAXv has a DS14C89 line driver which has internal filters.  The
MAXnet does not utilize the DS14C89 driver."
I'm still waiting for a fix from ACS to add filters to the limit lines
of their SPI-MAXnet-8000.  It is mostly unusable in its default state.
Kevin
Command omsMAXnetConfig not found David Vine
Re: Command omsMAXnetConfig not found Kevin Peterson
Re: Command omsMAXnetConfig not found David Vine
Prev: Re: Command omsMAXnetConfig not found Kevin Peterson
Next: Using synApps calc in simple IOC Iain Marcuson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
