I did not see any error in what you sent, only a warning. So I think it actually built OK.
Sent from my iPhone
> On Feb 4, 2017, at 9:58 PM, Olanrewaju Ogunmola <[email protected]> wrote:
> Hi All,
> I'm a new Epic user and have successfully installed epic-base and asyn. however, I encounter the below error when i run make from the top directory of epic-modbus. Any advise on it.
> Thank you
> Lanre Ogunmola
> Graduate Research Affiliate
> University of Nebraska, Omaha
> make -C ./configure install
> make[1]: Entering directory '/home/steal/modbus-master/configure'
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
> mkdir O.Common
> make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
> T_A=linux-x86_64 install
> make[2]: Entering directory '/home/steal/modbus-master/configure/O.linux-x86_64'
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl checkRelease
> make[2]: Leaving directory '/home/steal/modbus-master/configure/O.linux-x86_64'
> make[1]: Leaving directory '/home/steal/modbus-master/configure'
> make -C ./modbusApp install
> make[1]: Entering directory '/home/steal/modbus-master/modbusApp'
> make -C ./src install
> make[2]: Entering directory '/home/steal/modbus-master/modbusApp/src'
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
> mkdir O.Common
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
> make[3]: Entering directory '/home/steal/modbus-master/modbusApp/src/O.linux-x86_64'
> echo "../O.Common/modbus.dbd : ../Makefile" >> modbus.dbd.d
> Expanding dbd
> /home/steal/base-3.14.12.5/bin/linux-x86_64/dbExpand -I. -I.. -I../O.Common -I../../../dbd -I/home/steal/asyn-master/dbd -I/home/steal/base-3.14.12.5/dbd -o modbus.dbd ../modbusInclude.dbd
> Installing created dbd file ../../../dbd/modbus.dbd
> mkdir ../../../dbd
> Installing dbd file ../../../dbd/modbusSupport.dbd
> Installing generic include file ../../../include/drvModbusAsyn.h
> mkdir ../../../include
> /usr/bin/gcc -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include ../drvModbusAsyn.c
> /usr/bin/gcc -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include ../modbusInterpose.c
> /usr/bin/g++ -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include ../testModbusSyncIO.cpp
> /usr/bin/ar -rc libmodbus.a drvModbusAsyn.o modbusInterpose.o testModbusSyncIO.o
> /usr/bin/ranlib libmodbus.a
> /usr/bin/g++ -o libmodbus.so -shared -fPIC -Wl,-hlibmodbus.so -L/home/steal/asyn-master/lib/linux-x86_64 -L/home/steal/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/home/steal/asyn-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/base-3.14.12.5/lib/linux-x86_64 -m64 drvModbusAsyn.o modbusInterpose.o testModbusSyncIO.o -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom -lpthread -lm -lrt -ldl -lgcc
> Installing shared library ../../../lib/linux-x86_64/libmodbus.so
> mkdir ../../../lib
> mkdir ../../../lib/linux-x86_64
> Installing library ../../../lib/linux-x86_64/libmodbus.a
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/registerRecordDeviceDriver.pl ../O.Common/modbus.dbd modbus_registerRecordDeviceDriver /home/steal/modbus-master > modbus.tmp
> mv modbus.tmp modbus_registerRecordDeviceDriver.cpp
> /usr/bin/g++ -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include modbus_registerRecordDeviceDriver.cpp
> modbus_registerRecordDeviceDriver.cpp:478:12: warning: ‘done’ defined but not used [-Wunused-variable]
> static int done = Registration();
> /usr/bin/g++ -c -D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -m64 -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/Linux -I../../../include -I/home/steal/asyn-master/include -I/home/steal/base-3.14.12.5/include/os/Linux -I/home/steal/base-3.14.12.5/include ../modbusMain.cpp
> /usr/bin/g++ -o modbusApp -L/home/steal/modbus-master/lib/linux-x86_64 -L/home/steal/asyn-master/lib/linux-x86_64 -L/home/steal/base-3.14.12.5/lib/linux-x86_64 -Wl,-rpath,/home/steal/modbus-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/asyn-master/lib/linux-x86_64 -Wl,-rpath,/home/steal/base-3.14.12.5/lib/linux-x86_64 -m64 modbus_registerRecordDeviceDriver.o modbusMain.o -lmodbus -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
> Installing created file ../../../bin/linux-x86_64/modbusApp
> mkdir ../../../bin
> mkdir ../../../bin/linux-x86_64
> make[3]: Leaving directory '/home/steal/modbus-master/modbusApp/src/O.linux-x86_64'
> make[2]: Leaving directory '/home/steal/modbus-master/modbusApp/src'
> make -C ./Db install
> make[2]: Entering directory '/home/steal/modbus-master/modbusApp/Db'
> mkdir O.Common
> make[3]: Entering directory '/home/steal/modbus-master/modbusApp/Db/O.linux-x86_64'
> Installing template file ../../../db/bi_word.template
> mkdir ../../../db
> Installing template file ../../../db/bo_word.template
> Installing template file ../../../db/bi_bit.template
> Installing template file ../../../db/bo_bit.template
> Installing template file ../../../db/longin.template
> Installing template file ../../../db/longout.template
> Installing template file ../../../db/longinInt32.template
> Installing template file ../../../db/longoutInt32.template
> Installing template file ../../../db/mbbiDirect.template
> Installing template file ../../../db/mbboDirect.template
> Installing template file ../../../db/ai.template
> Installing template file ../../../db/ai_average.template
> Installing template file ../../../db/ao.template
> Installing template file ../../../db/aiFloat64.template
> Installing template file ../../../db/aoFloat64.template
> Installing template file ../../../db/intarray_in.template
> Installing template file ../../../db/intarray_out.template
> Installing template file ../../../db/stringin.template
> Installing template file ../../../db/stringout.template
> Installing template file ../../../db/stringWaveformIn.template
> Installing template file ../../../db/stringWaveformOut.template
> Installing template file ../../../db/statistics.template
> Installing template file ../../../db/asynRecord.template
> Installing template file ../../../db/poll_delay.template
> Installing template file ../../../db/poll_trigger.template
> make[3]: Leaving directory '/home/steal/modbus-master/modbusApp/Db/O.linux-x86_64'
> make[2]: Leaving directory '/home/steal/modbus-master/modbusApp/Db'
> make[1]: Leaving directory '/home/steal/modbus-master/modbusApp'
> make -C ./iocBoot install
> make[1]: Entering directory '/home/steal/modbus-master/iocBoot'
> make -C ./iocTest install
> make[2]: Entering directory '/home/steal/modbus-master/iocBoot/iocTest'
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/steal/modbus-master envPaths
> perl /home/steal/base-3.14.12.5/bin/linux-x86_64/convertRelease.pl -a linux-x86_64 -t /home/steal/modbus-master cdCommands
> make[2]: Leaving directory '/home/steal/modbus-master/iocBoot/iocTest'
> make[1]: Leaving directory '/home/steal/modbus-master/iocBoot'
- Epic-modbus build error Olanrewaju Ogunmola
Re: edm, Fedora 25, and Wayland Pierrick Hanlet
<2017>
2025
2026
EPICS Driver for FTDI D2XX on Linux Juniper Willard
<2017>
2025
2026
