Hello,
I’m using the 4.2 CS-Studio sources and I try to build the Spiral2 operation version. I execute my version in RCP e4 compatibility mode and use a application model (xmi file). I still face problems.
When I try to create a Logbook entry with popup menu or action button.
The java stack :
!ENTRY org.eclipse.ui 4 0 2017-02-10 10:05:22.579
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4491)
at org.eclipse.swt.SWT.error(SWT.java:4406)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:138)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3794)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3433)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:827)
at org.eclipse.jface.window.Window.open(Window.java:803)
at org.csstudio.logbook.ui.OpenLogEntryBuilderDialog.execute(OpenLogEntryBuilderDialog.java:45)
at org.csstudio.ui.util.AbstractAdaptedHandler.execute(AbstractAdaptedHandler.java:53)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:295)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:252)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:234)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:152)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:493)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:486)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:210)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:799)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:675)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:659)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:592)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4481)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1329)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3819)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3430)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.csstudio.spiral2_op.utility.product.Workbench.runWorkbench(Workbench.java:141)
at org.csstudio.startup.application.Application.startApplication(Application.java:264)
at org.csstudio.startup.application.Application.start(Application.java:118)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
at org.eclipse.equinox.launcher.Main.main(Main.java:1488)
Caused by: java.lang.NullPointerException
at org.csstudio.logbook.ui.LogEntryWidget.updateUI(LogEntryWidget.java:1088)
at org.csstudio.logbook.ui.LogEntryWidget.access$16(LogEntryWidget.java:1000)
at org.csstudio.logbook.ui.LogEntryWidget$20$3.run(LogEntryWidget.java:884)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
... 53 more
Thanks
Préservons notre environnement, n’imprimez ce mail que si nécessaire.
Preserve our environment, print this email only if necessary.
BEGIN:VCARD
VERSION:2.1
X-MS-SIGNATURE:YES
N;LANGUAGE=fr:PATARD;Charles-Henry
FN:Charles-Henry PATARD
ORG:GANIL;SDA/GIM
TEL;WORK;VOICE:(02) 31 45 49 05
ADR;WORK;PREF:;;Boulevard Henri Becquerel;Caen;;14000;France
LABEL;WORK;PREF;ENCODING=QUOTED-PRINTABLE:Boulevard Henri Becquerel=0D=0A=
14000 Caen France
X-MS-OL-DEFAULT-POSTAL-ADDRESS:2
EMAIL;PREF;INTERNET:[email protected]
X-MS-CARDPICTURE;TYPE=JPEG;ENCODING=BASE64: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X-MS-OL-DESIGN;CHARSET=utf-8:<card xmlns="http://schemas.microsoft.com/office/outlook/12/electronicbusinesscards" ver="1.0" layout="left" bgcolor="ffffff"><img xmlns="" align="fit" area="16" use="cardpicture"/><fld xmlns="" prop="name" align="left" dir="ltr" style="b" color="000000" size="10"/><fld xmlns="" prop="org" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="title" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="dept" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="telwork" align="left" dir="ltr" color="000000" size="8"><label align="right" color="626262">Bureau</label></fld><fld xmlns="" prop="email" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="addrwork" align="left" dir="ltr" color="000000" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/><fld xmlns="" prop="blank" size="8"/></card>
REV:20140210T091139Z
END:VCARD
BEGIN:VCARD
VERSION:2.1
X-MS-SIGNATURE:YES
ORG:GANIL;SDA/GIM
14000 Caen France
/9k=
END:VCARD
RE: VAL field in Motor record Default unit Mooney, Tim M.
Re: Long string command to device Dirk Zimoch
<2017>
2025
2026
RE: VAL field in Motor record Default unit Mark Clift
RE: Logbook entry error Patard Charles-Henri
<2017>
2025
2026
