Hello EPICS Developers,
First off all, I'm an EPICS novice, so my apologies if this question is
silly. I recently implemented a sequencer on a small machine here at the
University of Washington. I noticed some behavior that I'm having
trouble understanding. I have a work around, but I just want to make
sure this is intended behavior. If it isn't, and I've got something
screwed up, I'll just keep trouble shooting and try to figure what I'm
doing wrong. Basically, when the sequencer does a "pvPut" to a PV that
is located in an IOC that is not local to the machine, the write doesn't
appear to happen until after a subsequent "pvPut" is performed on a
local PV.
For example, running the template in,
epics/template/makeBaseApp/top/example
and modifying the snsExample.stt file to read:
user@pc:~/example$ more exampleApp/src/sncExample.stt
program sncExample
int local_pv;
int remote_pv;
assign local_pv to "Local:PV";
assign remote_pv to "Remote:PV";
monitor local_pv;
monitor remote_pv;
ss ss1 {
state init {
when (delay(5)) {
printf("sncExample: Startup delay over\n");
} state low
state low {
when (delay(5)) {
// Setting a remote PV to 1
remote_pv=1;
pvPut(remote_pv);
// Waiting for 5 seconds
epicsThreadSleep(5.0);
// Setting a local PV to 1
local_pv=1;
pvPut(local_pv);
} state high
state high {
when (0) {
} state low
with a "bo" record "Local:PV" running in local database, and a "bo"
record, "Remote:PV" on a different PC, here is what I observed with
camonitor when I ran the sequencer:
user@pc:~/EPICS_Apps/example/exampleApp/src$ camonitor Remote:PV
Local:PV
Local:PV 2017-02-08 13:58:41.904252 0
Remote:PV 2017-02-08 13:58:31.645527 0
Local:PV 2017-02-08 13:58:56.939562 1
Remote:PV 2017-02-08 13:58:56.940262 1
It seems like the PV located on a different machine, "Remote:PV", does
not get written until after "Local:PV" is written. It should be 5
seconds before. The behavior is the same if states are changed in
between PV puts.
Is that standard behavior?
Thanks everyone,
Toby
- Re: Sequencer remote pvPut CA delay (specified behavior?) Andrew Johnson
Re: VAL field in Motor record Default unit Joey Thai
<2017>
2025
2026
RE: Basler HD Camera device support tom.cobb
<2017>
2025
2026
