1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Question about PV operation that defined in ai.template.
Date: Fri, 24 Feb 2017 04:09:22 +0000
    I want to make an operation on part of PV that defined in ai.template. (namely:EMS-ARSM:Neutron:ChangeUnit001, EMS-ARSM:Neutron:ChangeUnit002,EMS-ARSM:Gamma:ChangeUnit001 )
    So, I add operation field in ai.template and also copy the file to Db folder and recompiled again.
    I have posted ai.template in the following lines:
#====================ai.tempalte========================
# ai record template
record (ai, "$(P)-$(S):$(NAME)$(NUM)")
  field (DTYP, "lrpApp")
  field (INP,  "@Monitor:$(INDEX)/$(OFFSET) L=$(LENGTH)")
  field (FLNK, "REMS-ARSM:Neutron:ChangeUnit001")
  field (FLNK, "REMS-ARSM:Neutron:ChangeUnit002")
  field (FLNK, "REMS-ARSM:Gamma:ChangeUnit003")
  field (ASLO,"$(ASLO)")
  field (LINR, "LINEAR")
  field (SCAN, "I/O Intr")
  field (HIHI, "$(HIHI)")
  field (LOLO, "$(LOLO)")
  field (HIGH,"$(HIGH)")
  field (LOW,"$(LOW)")
record (calc, "REMS-ARSM:Neutron:ChangeUnit001")
        field(INPA, "REMS-ARSM:AlphaCountRate001.VAL")
        field(CALC, "A*0.1")
        field(EGU,  "uSv/h")
record (calc, "REMS-ARSM:Neutron:ChangeUnit002")
        field(INPA, "REMS-ARSM:AlphaCountRate002.VAL")
        field(EGU,  "uSv/h")
record (calc, "REMS-ARSM:Gamma:ChangeUnit003")
        field(INPA, "REMS-ARSM:AlphaCountRate003.VAL")
        field(EGU,  "uSv/h")
#====================end of ai.tempalte=====================
here is the content of REMS_ARSM.substitutions (load "ai.template") file that used in st.cmd file to launch the IOC:
#=========================REMS_ARSM.substitutions================
file "db/ai.template" { pattern
{P,      S,       NAME,             NUM,    INDEX,      OFFSET,     LENGTH,      ASLO,     HIHI,             HIGH,               LOLO,         LOW}
{REMS, ARSM,     AlphaCountRate,    001,      21,        100,          5,        0.1,        50,              20,                 3,             0}
#====================end of REMS_ARSM.substitutions================
However, when started IOC I failed to do the operation and the result dislpayed in terminal:
epics> dbpr REMS-ARSM:Neutron:ChangeUnit001
A: 0                ASG:                B: 0                C: 0
CALC: A*0.1         D: 0                DESC:               DISA: 0
DISP: 0             DISV: 1             E: 0                F: 0
G: 0                H: 0                I: 0                J: 0
K: 0                L: 0                NAME: REMS-ARSM:Neutron:ChangeUnit001
SEVR: INVALID       STAT: UDF           TPRO: 0             VAL: 0
Could you give me some suggestions and thanks in advance !
Zhefu
RE: Question about PV operation that defined in ai.template. Mark Rivers
Prev: Re: memory leak after unloading of ca.lib Michael Davidsaver
Next: RE: Question about PV operation that defined in ai.template. Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Why we want Lua on the IOC Hill, Jeff
