Hi, I am installed BURT in a sl7.2 machine but while logging the files through command line as well as burt gooey, the below error pops up Error log while using burtrb through command line [vishrut@localhost linux-x86_64]$ ./burtrb -f req1.req -o snap1.snap -l /tmp/burtlog.read.log **** The executable "caRepeater" couldn't be located **** because of errno = "No such file or directory". **** You may need to modify your PATH environment variable. **** Unable to start "CA Repeater" process. burtlog.read.log reads as &column ... not connected so no ca_array_get_callback() &column ... not connected so no ca_array_get_callback() &column ... not connected so no ca_array_get_callback() &column ... not connected so no ca_array_get_callback() &column ... not connected so no ca_array_get_callback() &column ... not connected so no ca_array_get_callback() &data ... not connected so no ca_array_get_callback() HPE3631ATestGetP25Volts ... not connected so no ca_array_get_callback() Error log while using backup through GUI [vishrut@localhost linux-x86_64]$ ./burtgooey >burtrb -f /opt/epics/extensions/bin/linux-x86_64/req1.req -o vishrut_1170303_152653_0.snap -l /tmp/vishrut_1170303_152653_0.read.log -v < sh: burtrb: command not found Kindly suggest a solution for this. Thanks Arnab
| ANJ, 21 Dec 2017 |
Home
News
About
Talk
Base
Modules
Extensions
