1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 3.15 build rules suppress crash message [was: EPICS make problem]
To: Ralph Lange <[email protected]>
Date: Wed, 8 Mar 2017 10:39:20 -0600
On 03/08, Ralph Lange wrote:
> Have you verified the return code of the segfaulting command? I think make
> uses that to determine if the command failed. IIRC, we had cases in Base
> where a failing script would not return 0 because of an output redirection.
You mean "would return 0" I assume.
Lewis
EPICS make problem Benjamin Franksen
Re: EPICS make problem Torsten Bögershausen
3.15 build rules suppress crash message [was: EPICS make problem] Ben Franksen
Re: 3.15 build rules suppress crash message [was: EPICS make problem] Ralph Lange
Prev: Re: 3.15 build rules suppress crash message [was: EPICS make problem] Ralph Lange
Next: call of ca_sg_test hangs on in preemptive mode Wang Xiaoqiang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: 3.15 build rules suppress crash message [was: EPICS make problem] Ben Franksen
