1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS make problem
To: <[email protected]>
Date: Thu, 9 Mar 2017 18:15:16 -0600
Hi Ben,
I have an explanation, but it isn't complete. Look carefully:
On 03/07/2017 08:32 AM, Benjamin Franksen wrote:
> franksen@tiber: ...test/validate/O.linux-x86 > make
> make -f ../Makefile TOP=../../.. T_A=linux-x86  all
This is the first pass through the Makefile:
> make[1]: Entering directory
> `/home/franksen/src/seq/branch-2-3/home/test/validate/O.linux-x86'
> perl /home/franksen/src/epics-base/3.14/bin/linux-x86/mkmf.pl -m
> wait.st.d  .  ../os/Linux ../os/posix ../os/default ..  wait.i ../wait.st
> make[1]: Leaving directory
End of first pass, during which it generated the wait.st.d file, which
GNUmake regards as part of the Makefile because that generated file is
listed in an include statement. During the first pass GNUmake's aim is
to build the Makefile. Then GNUmake reloads the Makefile and all its
includes and runs the second pass to build the target we asked it for:
> preprocessing ../wait.st
> /usr/bin/gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_
>  -DUNIX  -Dlinux   -I. -I../O.Common -I. -I..
> -I../../../include/os/Linux -I../../../include
> -I/home/franksen/src/epics-base/3.14/include/os/Linux
> -I/home/franksen/src/epics-base/3.14/include        ../wait.st > wait.i
> compiling wait.i to C
> /home/franksen/src/seq/branch-2-3/home/bin/linux-x86/snc   +m  wait.i -o
> wait.c.tmp
> make[1]: *** [wait.c] Segmentation fault (core dumped)
The snc program was run in the second pass, but died and an error
message was printed.
Compare with the 3.15 run following (I removed the 'waitfun.*' lines
from your original message as they weren't relevant to the issue and
might have been slightly confusing if left in):
Here's the first pass through the Makefile again:
>  -DUNIX  -Dlinux   -I. -I../O.Common -I. -I. -I..
> -I../../../include/compiler/gcc -I../../../include/os/Linux
> -I../../../include
> -I/home/franksen/src/epics-base/3.15/include/compiler/gcc
> -I/home/franksen/src/epics-base/3.15/include/os/Linux
> -I/home/franksen/src/epics-base/3.15/include        ../wait.st > wait.i
> wait.c.tmp
Wasn't that the same snc command which died in the 3.14 build?
> perl -CSD /home/franksen/src/epics-base/3.15/bin/linux-x86/mkmf.pl -m
> wait.st.d  .  ../compiler/gcc ../compiler/default .  ../os/Linux
... but we've only now got to the end of the first pass through the
Makefile. Here's the second pass after the wait.st.d file has been
created and the Makefile has been reloaded:
> wait.c.tmp
> make: *** [all] Error 2
The second pass ends here, presumably because the snc command died again.
One of the significant differences between the first and second passes
of the Makefile is that recipes needed for rebuilding Makefiles can fail
in the first pass and GNUmake will ignore those failures if the file it
was trying to build was included with a '-include' statement (which our
dependency files usually are).
The EPICS build system used to suppress echoing of commands that
generated the dependency files, but they are now displayed as it's much
less confusing. You can see what GNUmake is doing by adding --debug=m
which generates somewhat verbose output but is useful in these kinds of
situations, it explains what's happening during both passes whereas
--debug=b only explains the second pass.
I don't have time right now to explain in detail what's different about
the EPICS build systems between 3.14 and 3.15, basically we split off
the commands that generated dependency (.d) files from those that do
compilation, so in 3.15 we generate the .d files during the first pass
whereas in 3.14 they were generated during the build step.
Got to go now, hope this helps.
- Andrew
Re: EPICS make problem Ben Franksen
EPICS make problem Benjamin Franksen
Prev: DAQ/Controls software position Hartman, Steven M.
Next: Questions about css boy opi be run as a standalone program lzf neu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: 3.15 build rules suppress crash message [was: EPICS make problem] Ben Franksen
Next: Re: EPICS make problem Ben Franksen
