1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Asyn 4-30 Problem on Arm processor
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 17 Mar 2017 12:18:53 +0000
Did you set the asynFloat64Mask bit in your call to the asynPortDriver base class constructor?
Perhaps you should send me your driver files.
From: [email protected] [[email protected]] on behalf of Jörn Dreyer [[email protected]]
Sent: Friday, March 17, 2017 7:02 AM
To: [email protected]
Subject: Re: Asyn 4-30 Problem on Arm processor
Hi Mark,
I could not use StreamDevice because of hardware issues. It turned out that
these devices need special configurations of the serial interface which can not
be set using the standard asynSerialPort driver. In addition there are some
commands that need to combine the values from more than one PV into the output
stream.
Removing PINI in all records did not change the result.
I'm trying now which of the records is causing the problem.
As soon as I include one record with type asynFloat64 it crashes.
 I will try tu run the code on x86_64 under vagrind and see what happens.
Jörn
Asyn 4-30 Problem on Arm processor Jörn Dreyer
Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
RE: Asyn 4-30 Problem on Arm processor Mark Rivers
Prev: Re: Asyn 4-30 Problem on Arm processor Jörn Dreyer
Next: Re: Asyn 4-30 Problem on Arm processor Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
