1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS IOC asynMotorController error
To: Marissa Elizabeth Kranz <[email protected]>
Cc: Matt Dentinger <[email protected]>, "[email protected] list" <[email protected]>
Date: Wed, 22 Mar 2017 14:00:51 +0000
I’ve not worked with DC motors with that driver (only steppers). However you could check the motor type setting. The PV name might be DMC01:A:A_MTRTYPE_CMD.
Also check the drive enable signal (DMC01:A:A_ON_CMD) which should be “On”
If there’s an issue with limits then either .HLS or .LLS will be set to 1.
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
> On Mar 21, 2017, at 6:55 PM, Marissa Elizabeth Kranz <[email protected]> wrote:
> Hello,
> I am working on a project involving the control of 40 brushed DC motors by the Galil DMC 4080 controller. We have an IOC shell set up with encoder feedback that the motor is tracking (if we move the motor shaft a bit then it corrects itself to the encoder position), but whenever we try to send the motor to a specified position through the motor record's VAL field we receive the following error:
> epics> dbpf DMC01:A.VAL 40
> DBR_DOUBLE:         40
> epics> move begin failure axis A
> 2017/03/21 15:46:03.777 asynMotorController:writeFloat64 error, status=3 axis=0, function=1, value=888.888889
> Has anyone encountered this same error and knows what causes this output?
> Thanks so much,
> Marissa Kranz
Re: EPICS IOC asynMotorController error Ron Sluiter
EPICS IOC asynMotorController error Marissa Elizabeth Kranz
Prev: RE: EPICS IOC asynMotorController error Mark Rivers
Next: Re: EPICS IOC asynMotorController error Ron Sluiter
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
