1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Questions about EDM and any help will be appreciated.
Date: Mon, 27 Mar 2017 14:16:16 +0000
I have installed the latest version of edm(1-12-105) and I have two questions about edm to consult you:
(1) When drawing objects, the left side of object properties window does not fully displayed on my fedora20-64bit system and no scroll bar in the bottom.  I don't know why and I have attatched the screenshot in pdf format in the attatchment (static text properties window for example ).
(2) Click "Help-->Objects-->Png Image" button, EDM msgbox show that it needs font "helvetica-bold-r-20.0".  I also have attatch the screenshot in pdf format in the attatchment. however, I have already installed the fonts by using command:
yum install *75dpi*
xset fp+ /usr/share/X11/fonts/75dpi
but edm still report that it needs font "helvetica-bold-r-20.0".
Any help will be appreciated and thanks in advance!
Zhefu
Attachment: (1)properties-window.pdf
Description: (1)properties-window.pdf
Attachment: (2)font-problem.pdf
Description: (2)font-problem.pdf
Prev: Re: Vxworks nfs write error? Lawson, Gregory S.
Next: CSS-BOY change field satus in runtime Miguel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: CSS Alarm Handler Status Messages Kasemir, Kay
