1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Question about PV name by using pcaspy
Date: Wed, 29 Mar 2017 07:37:58 +0000
I want to fulfill a goal that when running camonitor command, PV name TEST:PING in the terminal window print "Disconnect!" or "OK!" alternatively.
However, I failed, "self.setParam('PING',a)"  seems only run once in the code and in terminal window only print one result.
I have posted the code in the following lines.
Could you give me some suggestions and any help will be appreciated.
Zhefu
#!/usr/bin/env python
import os
import threading
import time
from pcaspy import Driver, SimpleServer
prefix = 'TEST:'
pvdb = {
    'PING' : {
         'type':'enum',
         'enums':['Disconnect!','OK!']
class myDriver(Driver):
    def __init__(self):
        super(myDriver, self).__init__()
        tid=threading.Thread(target=self.determine)
        tid.setDaemon(True)
        tid.start()
    def determine(self):
        a=os.system("ping -c 1 -w 1 127.0.0.1")
        if (a==0):
          while True:
             a=not a
             time.sleep(5)
if __name__ == '__main__':
    server = SimpleServer()
    server.createPV(prefix, pvdb)
    driver = myDriver()
    # process CA transactions
    while True:
        server.process(0.1)
Re: Question about PV name by using pcaspy Kasemir, Kay
Prev: Re: INP string length Konrad, Martin
Next: Re: Question about PV name by using pcaspy Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: INP string length Michael Davidsaver
