1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: PCAS (using pcaspy) in docker ""server isnt attached to a network"
Date: Thu, 30 Mar 2017 16:58:52 +0000
If I try to run pcaspy in docker, I get the following error in CAS:
filename="../../../../src/cas/io/bsdSocket/casDGIntfIO.cc" line number=121
server isnt attached to a network - unable to continue
filename="../../../../src/cas/io/bsdSocket/caServerIO.cc" line number=116
Attempt to set server's IP address/port failed unable to attach explicit interface
filename="../../../../src/cas/generic/caServerI.cc" line number=59
server isnt attached to a network - CA server internals init unable to continue
terminate called after throwing an instance of 'int'
I understand that this has something to do with CAS's interface detection. However, if I run `softIOC` with the following db
echo "record(ai,"test_pv") {
field(VAL,"3")
}" > test.db
softIOC -d test.db
It works fine and I can `caget testpv` from another container without issue. This leads me to believe that the plumbing is there but that there is some assumption made in how CAS detects broadcast interfaces that is not holding true in docker.
Have you all been able to successfully run pcaspy  or cas-based servers in docker? Are there some environment variables I can set to help cas along?
I should note that setting `EPICS_CAS_INTF_ADDR_LIST="localhost"` WILL allow pcaspy will run in docker, but then the PVs are not visible outside that docker container, so it's not that useful.
Also for reference, here is what ifconfig returns from inside the container:
ifconfig
eth0      Link encap:Ethernet  HWaddr 02:42:ac:11:00:02
          inet addr:172.17.0.2  Bcast:0.0.0.0  Mask:255.255.0.0
          inet6 addr: fe80::42:acff:fe11:2/64 Scope:Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:237 errors:0 dropped:0 overruns:0 frame:0
          TX packets:186 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:240235 (234.6 KiB)  TX bytes:11013 (10.7 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:3 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1
          RX bytes:208 (208.0 B)  TX bytes:208 (208.0 B)
Thanks for the help,
John Sparger
Re: PCAS (using pcaspy) in docker ""server isnt attached to a network" Andrew Johnson
Prev: 答复: Question about PV name by using pcaspy lzf neu
Next: Re: Question about PV name by using pcaspy Xiaoqiang Wang
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Question about PV name by using pcaspy Xiaoqiang Wang
Next: Re: PCAS (using pcaspy) in docker ""server isnt attached to a network" Andrew Johnson
