Subject: Re: stringout in softIOC
To: <[email protected]>
Date: Mon, 3 Apr 2017 14:08:16 -0500
Hi Al,
On 04/03/2017 12:45 PM, Al Honey wrote:
> There are two records (in my contrived example below) the only
> difference between the two records is in the DOL field, [UBACKLASH]
> versus [“UBACKLASH”].
Straight away I can tell you that in 3.14 and 3.15 a DOL field can only
be used to constant-initialize any record's VAL field when the DOL field
contains a number. It's a bit complicated, but the issue is that for it
to recognized and treated as a CONSTANT link value the value string has
to be completely convertible into either a double using strtod() or into
a long using strtol(). If the string value fails those tests it must be
a PV_LINK so will be passed first to the DB link code and if lookup
there fails to the CA link code.
To initialize the value of a stringin or stringout record you should set
the VAL field directly in the .db file.
In 3.16 we're going to allow you to provide constant links containing
both strings and even arrays, but we can't retro-fit this into older
Base versions.
> soutT1 is loaded and the DOL field is interpreted as a CA_LINK and the
> OUT field as DB_LINK.
Expected, as described above.
> soutT2 has the value of DOL in double quotes, which was my attempt to
> force it to be a constant. When loaded both DOL and OUT get set to
> CONSTANT. The DOL value is lost and I don’t understand why OUT does not
> remain as a DB_LINK.
> record(stringout,"soutT2") {
>     field(DESC,"string output record")
>     field(SCAN,"Passive")
>     field(DTYP,"Soft Channel")
>     field(VAL,"string")
>     field(DOL,""UBACKLASH"")
>     field(OMSL,"supervisory")
>     field(OUT,"param.VAL PP")
Did you get any warnings or errors when you loaded that database? I
don't think your DOL field setting was actually parsed as you think, the
second double-quote would have closed the string, but then the word
UBLACKLASH followed another empty string wouldn't have made sense to the
parser, so I think you should have got an error message from
dbLoadRecords(). That would also explain the field values you got:
> epics> dbpr soutT2,4
> DESC: string output record
> DOL:CONSTANT
> DTYP: Soft Channel
> OMSL: supervisory
> OUT:CONSTANT
> OVAL: string
> SCAN: Passive
> TSEL:CONSTANT
> VAL: string
HTH,
- Andrew
stringout in softIOC Al Honey
Prev: stringout in softIOC Al Honey
Next: Re: stringout in softIOC Andrew Johnson
