1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Dynamic alarm server
To: [email protected]
Date: Tue, 4 Apr 2017 11:47:37 +0100
We are currently looking at setting up a dynamic alarm server and have questions regarding its use.
Our current system has a configuration which defines which IOCs are running on our system. This is updated and changed depending on the experiment that a user is running. At the moment we can generate an xml file from it which contains the alarms we are interested in. This file is then imported into the alarm server database with AlarmConfigTool. Once this is in the database we then restart the alarm server and refresh the alarm server tree view to capture the changes in configuration. This doesn't seem like the correct way to do this, can someone offer some guidance. The sort of thing I would like to do is to send the xml configuration file to the alarm server and have it update its configuration and then notify the clients of this.
We are running IBEX as the client which is using the BEAST alarm CSS component to display the alarms. The configurations are changed by our BlockServer which is written in Python.
Thank you for your help,
John Holt
This message is commercial in confidence and may be privileged. It is intended for the
addressee(s) only. Access to this message by anyone else is unauthorized and strictly prohibited.
If you have received this message in error, please inform the sender immediately. Please note that
messages sent or received by the Tessella e-mail system may be monitored and stored in an
information retrieval system.
Re: Dynamic alarm server Kasemir, Kay
Re: Dynamic alarm server John . Holt
Prev: Re: Two VxWorks IOCs in one VME Crate Ralph Lange
Next: Re: Dynamic alarm server Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: stringout in softIOC Andrew Johnson
