Subject: RE: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays
To: 'Pawel Plewinski' <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 11 Apr 2017 16:24:53 +0000
Hi Pawel,
What is the SCAN field of your waveform record?  I suspect it is probably periodic ("1 second", etc.).  For this application you should set it to SCAN="I/O Intr".  Then the waveform record will process each time your driver does a callback to device support.  If the record is periodically processing at 1 second and your driver is doing callbacks faster than 1 Hz then you will see the error you report.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of Pawel Plewinski
Sent: Tuesday, April 11, 2017 8:49 AM
To: [email protected]
Subject: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays
I've recently written asyn-based device support for a custom device
communicating over PCIe. One of its functions is to periodically
retrieve 4 waveforms from 4 channels, which is done in a separate
thread, from which the callback function is called to notify asyn about
change. I heavily based the code on the AsynPortDriver example.
The driver works, however if the update rate is lower than 1 second,
strange warning appears in the console at the time of every refresh (and
that's only for one of 4 channels), namely:
2017/04/11 15:42:08.682 PIEZO:OSC-CH0-WAVEFORM
devAsynFloat64Array::interruptCallbackInput
\000\000\000\000\000@\205?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?\000\000\000\000\000@\205?\000\000\000\000\000\000\204?\000\000\000\000\000\300\202?\000\000\000\000\000\000\204?
devAsynFloat64Array::processCommon, warning, multiple interrupt
The parameters passed to the top level constructor are
    : asynPortDriver(portName,
                     4, /* maxAddr */
                     (int)NUM_SCOPE_PARAMS,
                     asynInt32Mask | asynFloat64Mask |
asynFloat64ArrayMask | asynEnumMask | asynDrvUserMask, /* Interface mask
asynFloat64ArrayMask | asynEnumMask,  /* Interrupt mask */
                     ASYN_MULTIDEVICE, /* asynFlags.  This driver does
not block and it is not multi-device, so flag is 0 */
                     1, /* Autoconnect */
                     0, /* Default priority */
                     0) /* Default stack size*/
The readback thread code:
void piezoPortDriver::readbackTask(void)
    while (1) {
            bool stopped = false;
            lock();
            auto new_data = osc->fetch_data(vtim, vdat);
            unlock();
            if (!stopped)
                lock();
                this->osc_update_trigger();
                unlock();
         callParamCallbacks();
         for (int i = 0; i < 4; i++){
           doCallbacksFloat64Array(vdat[i].data(), vdat[i].size(),
P_OscWaveform, i);
         usleep(100000);
The fetch_data method reads four 1000-element double vectors from PCIe.
Could you give me some suggestions what may be wrong?
Paweł Plewiński
Department of Microelectronics and Computer Science
Lodz University of Technology
Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Ralph Lange
Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
Prev: RE: CA client within Asyn Mooney, Tim M.
Next: RE: CA client within Asyn Mark S. Engbretson
Prev: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Paweł Plewiński
Next: Re: [AsynPortDriver] "Multiple interrupt callbacks between processing" warning with multiple arrays Ralph Lange
