Subject: RE: Writing Area Detector Monitor
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 14 Apr 2017 15:51:27 +0000
I've been studying the Mythen driver, but I am quite puzzled on how the EPICS side talks to the C/C++ side.  Are there any references on the C/C++ bindings?
Thank you,
Iain Marcuson.
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Tuesday, April 11, 2017 5:16 PM
> To: Iain Marcuson <[email protected]>; tech-
> [email protected]
> Hi Iain,
> The drivers which directly receive images over the network are ADPSL,
> ADPixirad,  ADMerlin,  and ADMythen.
> Many other drivers receive images over the network, but they do this
> through a vendor API (e.g. ADProsilica, aravisGigE, ADPointGrey, etc.).
> If you want to create a driver which works like other areaDetector drivers
> you should not use StreamDevice for the command/response, you should do
> it through the driver itself.  Your driver will receive a call each time the user
> changes things like exposure time, acquire start/stop, frame binning, etc.
> You can talk to the device from your driver using the asynIPPort driver and
> the asynOctetSyncIO interface. All of the drivers I listed above do that so you
> can see how to do it.
> Mark
> From: Iain Marcuson [mailto:[email protected]]
> Sent: Tuesday, April 11, 2017 3:54 PM
> To: Mark Rivers; [email protected]
> > Do you mean that you have a device that sends images over a network
> > port, and you would like to create an areaDetector driver to receive those
> images?
> > The driver would convert the images into NDArrays in an EPICS IOC, and
> > thus be able to use the areaDetector plugins for file saving, image
> > processing, and sending images to EPICS Channel Access clients, etc.?
> The device would send images over a network port, and we would be looking
> to convert them into NDArrays as you describe.
> > If this is what you want to do then you can use one of the existing
> > areaDetector drivers as a model.  Those create a complete application
> > to control and read data from a specific type of camera or detector.
> > Can you describe your device a bit more, so I know which existing
> > driver to recommend as a starting point?  Can you control the device
> > from your driver (exposure time, start/stop, etc.)?  If so are those
> > ASCII commands?  Is it TCP/IP or some other protocol?  Is the image data in
> binary?
> The device would be controlled via an IOC.  We will likely use Stream Device,
> which we have used successfully for a similar control scheme.  The
> commands would be ASCII based.  The image data is in binary, and at present
> we are looking towards UDP, although we may use TCP.
RE: Writing Area Detector Monitor Mark S. Engbretson
RE: Writing Area Detector Monitor Mark Rivers
Writing Area Detector Monitor Iain Marcuson
RE: Writing Area Detector Monitor Iain Marcuson
Prev: Re: Archiver Appliance established multiple CA connections for one channel Andrew Johnson
Next: RE: Writing Area Detector Monitor Mark S. Engbretson
Prev: RE: Writing Area Detector Monitor Iain Marcuson
