1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem in macLib macExpandString?
To: EPICS Tech-Talk <[email protected]>
Date: Sun, 16 Apr 2017 19:41:55 +0000
I am trying to use macLib to do macro substitution in base 3.15.5.  It is generally working.  However sometimes when there is an undefined macro the return value from macExpandString is not negative when it should be.
This is the code I am using to call macExpandString, with some debugging printf calls.  It prints the value returned by macValueExpand, as well as the input and output strings.
        // Create a temporary buffer 10 times larger than input buffer
        int bufferSize = buffer.length() * 10;
        char *tmpBuffer = (char *)malloc(bufferSize);
printf("Calling macExpandString, input length=%d, output buffer size=%d\n", (int)buffer.length(), bufferSize);
        status = macExpandString(macHandle, buffer.c_str(), tmpBuffer, bufferSize);
printf("macExpandString returned %d\n", status);
printf("input:\n########\n%s\n########\n\n", buffer.c_str());
printf("output:\n########\n%s\n########\n\n", tmpBuffer);
Here is an example.  In this case the CAMERA macro is not defined.
Calling macExpandString, input length=1013, output buffer size=10130
macLib: macro CAMERA is undefined (expanding string <?xml version="1.0" standalone="no" ?>
<!-- Attributes -->
<Attributes
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance";
    xsi:noNamespaceSchemaLocation="../../../../../ADCore/XML_schema/NDAttributes.xsd"
    <Attribute name="AcquireTime"         type="EPICS_PV" source="$(CAMERA)AcquireTime"         dbrtype="DBR_NATIVE"  description="Camera acquire time"/>
    <Attribute name="RingCurrent"         type="EPICS_PV" source="S:SRcurrentAI"                dbrtype="DBR_NATIVE"  description="Storage ring current"/>
    <Attribute name="RingCurrent_EGU"     type="EPICS_PV" source="S:SRcurrentAI.EGU"            dbrtype="DBR_NATIVE"  description="Storage ring current units"/>
    <Attribute name="ID_Energy"           type="EPICS_PV" source="$(ID)Energy"                  dbrtype="DBR_NATIVE"  description="Undulator energy"/>
    <Attribute name="ID_Energy_EGU"       type="EPICS_PV" source="$(ID)Energy.EGU"              dbrtype="DBR_NATIVE"  description="Undulator energy units"/>
</Attributes>
macExpandString returned 1027
input:
<!-- Attributes -->
<Attributes
</Attributes>
output:
<!-- Attributes -->
<Attributes
    <Attribute name="AcquireTime"         type="EPICS_PV" source="$(CAMERA,undefined)AcquireTime"         dbrtype="DBR_NATIVE"  description="Camera acquire time"/>
    <Attribute name="ID_Energy"           type="EPICS_PV" source="ID13us:Energy"                  dbrtype="DBR_NATIVE"  description="Undulator energy"/>
    <Attribute name="ID_Energy_EGU"       type="EPICS_PV" source="ID13us:Energy.EGU"              dbrtype="DBR_NATIVE"  description="Undulator energy units"/>
</Attributes>
Note above that macExpand string is printing an error message as it should.  However, it is returning a positive integer 1037, while it should be returning a negative value because there was an undefined macro.
If instead of CAMERA being undefined I don't define ID instead I get this output:
macLib: macro ID is undefined (expanding string <?xml version="1.0" standalone="no" ?>
<!-- Attributes -->
<Attributes
</Attributes>
<!-- Attributes -->
<Attributes
</Attributes>
macExpandString returned -1036
input:
<!-- Attributes -->
<Attributes
</Attributes>
output:
<!-- Attributes -->
<Attributes
    <Attribute name="AcquireTime"         type="EPICS_PV" source="13SIM1:cam1:AcquireTime"         dbrtype="DBR_NATIVE"  description="Camera acquire time"/>
    <Attribute name="ID_Energy"           type="EPICS_PV" source="$(ID,undefined)Energy"                  dbrtype="DBR_NATIVE"  description="Undulator energy"/>
    <Attribute name="ID_Energy_EGU"       type="EPICS_PV" source="$(ID,undefined)Energy.EGU"              dbrtype="DBR_NATIVE"  description="Undulator energy units"/>
</Attributes>
This is behaving correctly, macExpandString is returning a negative number, -1036 as it should.
Am I doing something wrong or is this a bug?
RE: Problem in macLib macExpandString? Mark Rivers
Prev: Re: CAS: partial (damaged?) UDP msg Shen, Guobao
Next: RE: Problem in macLib macExpandString? Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
