1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS V4 Windows build warning messages.
To: <[email protected]>
Date: Wed, 19 Apr 2017 13:41:26 -0500
If one builds Epics V 4 on a windows box with Visual Studio 2013 Community, as either shared libraries or static, you get *hundreds* of warning messages that deal with <something> needing to have dll-interface to be used.
i.e.
warning C4251: 'epics::nt::NTEnum::URI' : class 'std::basic_string<char,std::char_traits<char>,std::allocator<char>>'
needs to have dll-interface to be used by clients of class 'epics::nt::NTEnum'
Does anyone know if this is actually an indication that things will most likely not work if, for example, one were to build AD2-6 with Epics V4 support?
Microsoft claims that the error is thrown when one is not separating the interface from the implementation. If clients should not be able to access these items, they should be made private and #pragma warning disable C4251 added to source. If they should be accessible, code added to access them.
I’m assuming the #pragma solution is a reasonable solution?
Re: EPICS V4 Windows build warning messages. Andrew Johnson
RE: EPICS V4 Windows build warning messages. Mark Rivers
Prev: RE: runtime problem Mark Rivers
Next: Re: EPICS V4 Windows build warning messages. Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: support for Cryomech CP950 compressor (part of PT405 cryorefrigerator) arvinder.palaha
