Subject: Re: ioc epics
To: "Al Baradan, Suraka" <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 20 Apr 2017 15:47:30 +0000
Hi:
On Apr 20, 2017, at 6:16 AM, Al Baradan, Suraka <[email protected]> wrote:
> i try to make ioc soft with epics on VDMK  but i have always the same error. Have you an Idee?
One of your errors is
  .. Can’t open include file “stream.dbd"
In your configure/RELEASE file, did you define the path to the stream device module?
Something like
STREAMDEVICE=/path/to/StreamDevice
The name “STREAMDEVICE” doesn’t matter, you can use “STREAM” or “MYSTREAM” or “ABCD”, but there must be a dbd/stream.dbd and lib/linux-x86_64/libstream.so in that StreamDevice directory.
Same goes for the ASYN module, you need an entry for that in the configure/RELEASE
-Kay
ioc epics Al Baradan, Suraka
Prev: Re: REceive only emails that i sent Andrew Johnson
Next: Re: EPICS V4 Windows build warning messages. Andrew Johnson
Next: Bandwidth limits in asyn Iain Marcuson
