1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Bandwidth limits in asyn
To: 'Iain Marcuson' <[email protected]>, "[email protected] >> EPICS Tech Talk" <[email protected]>
Date: Thu, 20 Apr 2017 20:46:42 +0000
What function does your readInt16Array function call to do the network transfer?  Are you using the native socket calls, i.e. recv() or recvfrom()?
Are you using the EPICS osiSock.h to make your driver portable to different OS?
When you say "the connection breaks" what exactly do you mean?  Is recv() or recvfrom() returning 0 or a negative number?
-----Original Message-----
Sent: Thursday, April 20, 2017 3:36 PM
To: Mark Rivers; [email protected] >> EPICS Tech Talk
I am calling my own asynPortDriver function with the readInt16Array method.  This is 1 Gbit Ethernet.  On my most recent run, it took 0.854 seconds to receive 19214960 bytes.
> From: Mark Rivers [mailto:[email protected]]
> Sent: Thursday, April 20, 2017 4:06 PM
> To: Iain Marcuson <[email protected]>; tech-
> [email protected] >> EPICS Tech Talk <[email protected]>
> How are you reading the data, i.e. are you calling the drvAsynIPPort driver
> from your driver?
> If so, how have you called drvAsynIPPortConfigure?  What value are you
> specifying for the timeout?
> Is this 1 Gbit Ethernet?
> What is the time between when you start the transfer and it breaks after
> 17640000 bytes?
> Mark
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Iain Marcuson
> Sent: Thursday, April 20, 2017 2:28 PM
> To: [email protected] >> EPICS Tech Talk
> Subject: Bandwidth limits in asyn
> I've been writing an asyn driver to receive data from a camera, but I seem to
> be hitting some sort of limit.  The total size to transmit is 35280000 bytes, but
> the connection breaks at around 17640000 bytes.  In a mockup test, I was
> able to transfer all the data by sending 16k with a pause of 0.5 seconds
> between each packet.  The receiving routine just buffers all the incoming
> data until it reads the predetermined amount.  Is there something else I
> need to be doing to get all the data?
> Thank you,
> Iain.
Bandwidth limits in asyn Iain Marcuson
RE: Bandwidth limits in asyn Mark Rivers
RE: Bandwidth limits in asyn Iain Marcuson
Prev: RE: Bandwidth limits in asyn Iain Marcuson
Next: Re: CSS binary color text Southern, Tim
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  <20172018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Bandwidth limits in asyn Iain Marcuson
