Subject: Re: CSS binary color text
Date: Fri, 21 Apr 2017 09:06:50 +0000
a solution implemented inside CSS would be the best option, in the meantime you
can use a Text Update with transparent background, plus a little script to be
executed as action hooking the mouse click to the script execution.
from org.csstudio.opibuilder.scriptUtil import PVUtil
status = PVUtil.getLong(widget.getPV())
if status == 0:
        widget.getPV().setValue(1)
else:
        widget.getPV().setValue(0)
Cheers,
Luca
On Fri, 2017-04-21 at 08:11 +0000, Southern, Tim wrote:
> Hi Miguel,
> You can change the value of almost any attribute of a CSS widget. There are
> predefined attributes listed in the Rules property that can change the
> behavior of a widget based on the value of a PV. The screen shot below shows
> how to define a foreground color rule based off a PV to be green when value is
> 1, else turn red.
> There appears to be no easy way to set the Off/On Label properties from the DB
> records ZNAM/ONAM fields. In (edm), there is a Label property that allows one
> to set the label value to (PV State or Literal).  I made a request on github
> for this option in BOY.  https://github.com/ControlSystemStudio/cs-studio/issu
> es/2189
> Cheers,
> -Tim Southern
> [email protected]
> From: <[email protected]> on behalf of Miguel <miguel.b.fernandes@
> gmail.com>
> Date: Thursday, April 20, 2017 at 10:44 AM
> Subject: Re: Fwd: CSS binary color text
> I also need to click over it to change the state.
> The only way i have so far is in fact to use the Image boolean button. I set
> the one severity field (OSV) to major .Then set in CSS the foreground to green
> and checked the ForeColor Alarm Sensitive to yes.
> But I am still not able to automatically use the ONAME and ZNAME fields in CSS
> so I have to manually set the ON and OFF label.
> Thanks
> On 18-04-2017 11:35, Luca Cavalli wrote:
> Hi Miguel,
> if you need to display only a text label you can use a Text Update widget with
> the transparent flag set, plus (as already suggested) a rule to change
> foreground color upon PV value.
> Cheers,
> Luca
> On Fri, 2017-04-14 at 19:15 +0100, Miguel wrote:
> Hello,
> I would like to do two things with my bo records in CSS.
> 1. Have a text that is according to the ONAM and ZNAM pv fields.
> 2. That this text is green in case of on and red othwerwise
> I only manage to do something similiat with an image boolean button
> (with no image and ON OFF predefined text)
> Thanks
<< Le informazioni contenute in questo messaggio di posta elettronica e relativi allegati sono riservate e confidenziali e ne è vietata la diffusione in qualunque modo eseguita. Qualora Lei non fosse la persona a cui il presente messaggio è destinato, La invitiamo ad eliminarlo e a darcene gentile comunicazione. Quanto precede ai fini del rispetto delle Legge 675/96 e del Decreto Legislativo 30/06/2003 n.196, sulla tutela dei dati personali >>
<< This e-mail is confidential and may well also be legally privileged. If you have received it in error, you are on notice of its status. Please notify us immediately by reply e-mail and then delete this message from your system. Please do not copy it or use it for any purposes, or disclose its contents to any other person: to do so could be a breach of confidence. Thank you for your co-operation. Please contact our IT Helpdesk on +3902380481 or email [email protected] if you need assistance >>
Re: CSS binary color text Southern, Tim
Prev: Re: CSS binary color text Southern, Tim
Next: Re: CSS binary color text Miguel
