Hi Andrew,
Thank you for the explanation. I've agreed that it is not important
thing to fix.
I will try to do if I have some peaceful time.
Han
On Mon, Apr 24, 2017 at 9:43 PM, Andrew Johnson <[email protected]> wrote:
> Hi Han,
> On 04/24/2017 07:27 AM, Jeong Han Lee wrote:
>> I am wondering the mixed data types in monitor function in
>> most_of_Record.c. For example, static void monitor(aiRecord *prec).
>> recGblResetAlarms function returns epicsUint16 (unsigned short) and the
>> returned value is used in different way according to its record, and
>> pass it as argument of db_post_events function with mixed data type.
>> All of them mixed data types are larger than its epicsUnit16, so no
>> problems I saw.
>> Is it just due to "history of Data types evolution" in many difference
>> records? If so, do we have any intention to keep the same data type in
>> entire (at least monitor function) EPICS layer? If any help is needed, I
>> can work on them.
> The value returned by recGblResetAlarms and accepted by db_post_events
> is a bitmap which tells the CA server which class of monitor events to
> send with this update. The individual bit values are defined in the CA
> header caeventmask.h as DBE_xxx macros and these values are used in the
> CA network protocol. Currently only the lowest 4 bits are used, so all
> values appear in the range 0..15.
> Adding additional bits would involve quite a lot of work; in addition to
> modifying the IOC core and/or all the record types it also needs changes
> to the CA client code and both CA servers (RSRV and CAS) in Base, in
> addition to updates to the CA Gateway. I think it unlikely that we would
> add many more events, if any.
> The differences between the individual record types is certainly
> historical, because there were many people involved in creating the
> standard set of types that come with Base. There are various things that
> we have cleaned up in the record type code over the years, but this one
> isn't something that we have bothered with. If you wanted to send us
> patches to unify the code we would be happy for the help, but I don't
> see this as being a particularly important thing to fix.
> HTH,
> - Andrew
> Arguing for surveillance because you have nothing to hide is no
> different than making the claim, "I don't care about freedom of
> speech because I have nothing to say." -- Edward Snowdon
- Data types in monitor function Jeong Han Lee
- Re: Data types in monitor function Andrew Johnson
Re: EPICS Archiver Appliance does not transfer PVs to "Being archived" Shankar, Murali
<2017>
2025
2026
CSS Service Panel [email protected]
<2017>
2025
2026
