Subject: Re: Switched PDUs with EPICS support
To: Tom Slejko <[email protected]>, Ziga Oven <[email protected]>
Date: Wed, 10 May 2017 15:27:42 +0200
These are also in use at PSI: https://www.gude.info/en/power-distribution/switched-pdu/expert-power-control-8210-8211.html
They are rack mountable, and for power supply there is only an IEC 20 connector, so you can order a power cord of any length for it.
Regards
Tomaž
On 10. 05. 2017 08:57, Tom Slejko wrote:
Hi all,
at PSI SwissFEL we use Gude PDUs throughout the facility: https://www.gude.info/en/power-distribution/switched-metered-pdu/expert-power-control-1202-series.html
EPICS device support is up and running and based on top of SNMP device support. For more info contact Tomaz Sustar ([email protected]) as he was working on it. IIRC the sources are not released to the public at the moment, but we can probably pull some strings to release it if you decide to go this way...
There were quite some problems with Gudes not properly renewing DHCP addresses (leading to duplicated IP addresses in the network!) but this was in large part resolved...
Not sure about the cord length though, as this was never an issue for us...
Tom
 Tom SLEJKO, Group Leader / Senior Control system engineer
 Email: [email protected]
 http://www.cosylab.com Phone: +41 76 687 7673
 Teslova ulica 30
 Skype: tomslejko
----- Original Message -----
To: "tech-talk" <[email protected]>
Sent: Wednesday, 10 May, 2017 02:02:58
Subject: Switched PDUs with EPICS support
Hi All,
We are looking for alternative to APC switched PDUs as we would like to
have cord longer than standard APC length of 12 feet.
http://www.apc.com/shop/us/en/products/Rack-PDU-Switched-1U-15A-100-120V-8-5-15/P-AP7900B
I have checked the EPICS modules page and I have found several other
options with existing support, but they all look a bit outdated (based
on part numbers on the page and cross-referencing them with current
vendor part numbers).
Are there other switched PDUs with EPICS support in use besides APC?
Žiga
Tomaž Šuštar
Control Systems Engineer
Radiology Protection Expert
Cosylab Switzerland
tel.: +41 56 310 2719
Switched PDUs with EPICS support Žiga Oven
Re: Switched PDUs with EPICS support Tom Slejko
Prev: RE: AreaDetector bindings and RBV propagation Mark Rivers
Next: Release 0.7.0 of pvaPy Andrew Johnson
Prev: Re: Switched PDUs with EPICS support Tom Slejko
Next: Re: Switched PDUs with EPICS support [email protected]
