Subject: Re: sending pickled python objects of epics channel access
To: "Madden, Timothy J." <[email protected]>
Date: Mon, 15 May 2017 17:20:00 -0500
Hi Tim,
On Mon, May 15, 2017 at 5:00 PM, Madden, Timothy J. <[email protected]> wrote:
Folks
This is probably a bad idea... But if I were to take a python object, call pickle.dumps() to convert it into a string, I
could then caput it to a waveform record. Then some other py client could caget, then call pickle.loads() from the
waveform record. then we get the object back.  So we are sending python objects over epics CA.
Has anyone tried this? Seems straightforward. Just how bad an idea is this?
There are a couple of potential problems with this approach:
      a) some Python objects cannot be easily pickled / unpickled.  Any object with a method would be in this category.
      b) the details of a pickled object can vary with Python version.
I think the better approach would be to convert the object to json and send that over the wire.  Well, and decide whether CA is the preferred Python-to-Python communication method ;).
--Matt
sending pickled python objects of epics channel access Madden, Timothy J.
Prev: sending pickled python objects of epics channel access Madden, Timothy J.
Next: Re: sending pickled python objects of epics channel access Andrew Johnson
