Subject: Re: sending pickled python objects of epics channel access
To: EPICS Tech Talk <[email protected]>
Date: Tue, 16 May 2017 13:26:29 +0900
On Tue, May 16, 2017 at 8:43 AM, Kasemir, Kay <[email protected]> wrote:
Also, pvAccess would eventually be the better choice, because it can natively send/receive custom data.
With the recently released update of pvaPy this appears almost trivial, but we have not used it in production, yet.
+1 for using pvAccess.
Not only would that remove the need for a mailbox waveform record on an IOC somewhere, which requires additional resources, administration and maintenance overhead and adds a size limit (NELM of the waveform) and a point of possible failure.
It will also perform better, as the data is only transferred once (server -> client) instead of twice (server -> mailbox -> client).
Cheers,
~Ralph
Re: sending pickled python objects of epics channel access Kasemir, Kay
sending pickled python objects of epics channel access Madden, Timothy J.
Re: sending pickled python objects of epics channel access Andrew Johnson
Prev: Re: sending pickled python objects of epics channel access Kasemir, Kay
Next: Re: sending pickled python objects of epics channel access Kasemir, Kay
